Redmak Administrators Posted November 25, 2012 Administrators Share Posted November 25, 2012 We can't upgrade to PHP 5.4 just like that. We also use eAccelerator so well have to see if that works at all or drop it Link to comment Share on other sites More sharing options...
hjf288 Posted November 25, 2012 Share Posted November 25, 2012 I have used MariaDB and yes It is faster, but it would take a lot of downtime for Neowin to convert to that. and nginx and php fpm makes a massive difference You are joking right? MariaDB is a drop in replacement so no it wouldn't be alot of downtime. PHP 5.4 has a compatible eaccelerator module however most commonly used are pecl-apc or xcache... Nginx serves static a hell of alot faster, but you lose .htaccess (Not a problem in itself as long as you define the rewrites/etc in your server config) Apache can run with php-fpm also via I think it was mod_fcgi(d) or something, never bothered looking into it as I prefer Nginx tbh.. Link to comment Share on other sites More sharing options...
Steven P. Administrators Posted November 25, 2012 Administrators Share Posted November 25, 2012 I would suggest litespeed, however there is a little problem and to resolve it would not be pretty and a certain memberbase would be ****ed. so nope to that. PM me to find out why (subs only) that as well as something else.... So helpful /s Guth 1 Share Link to comment Share on other sites More sharing options...
n_K Posted November 25, 2012 Share Posted November 25, 2012 I mentioned it aged ago, give hiphop a try! You don't need to compile the code anymore, just use the hiphop binary in the directory of the files and see if it works! Link to comment Share on other sites More sharing options...
remixedcat Posted November 26, 2012 Share Posted November 26, 2012 So helpful /s has to do with a certain type of content not being allowed on litespeed servers.... google it... Link to comment Share on other sites More sharing options...
DaveLegg Developer Posted November 26, 2012 Developer Share Posted November 26, 2012 has to do with a certain type of content not being allowed on litespeed servers.... google it... Regardless of the type of content in question, we're not going to use a piece of software where a third party gets to tell us what we can and can't put on our site. Hum, remixedcat and +Gary7 3 Share Link to comment Share on other sites More sharing options...
remixedcat Posted November 26, 2012 Share Posted November 26, 2012 Good going then!!! XD yey! Link to comment Share on other sites More sharing options...
Draconian Guppy Posted November 26, 2012 Share Posted November 26, 2012 Cloudflare wouldn't help us with speed. We've tried them before, and they only caused headaches. Every ime we made a change to a css file for example, cloudflare would show the 'site offline' page for a good 5-10 minutes, amongst other issues. From what I can tell, the issue isn't slow database queries either. If you hit post and then half a second later, open the thread again in another tab, you'll see your post there, whilst the initial tab is still loading. Obviously IPB does a lot of additional processing after the post is submitted, and I have no idea what this processing entails, but it's clearly that which is causing the slow processing problem, and when we get time, we will look into that thoroughly. I've noticed this several times, I usually hit "post" and it keeps "saving reply" for a good 2 minutes or more, BUT I can see my reply went through on the mini-spy. It's really annoying :/ remixedcat 1 Share Link to comment Share on other sites More sharing options...
