Jump to content
Small issue with USB2 device running on USB3...
  • Please log in to reply
19 replies to this topic
#16 majortom1981
majortom1981
    The crazy one
  • Tech Issues Solved: 1
Posted 24 December 2012 - 17:54
At work I have nothing but problems running USB 2 devices on USB 3 ports. 90 0percent of the time I get blue screens when you plug ina USB 2 devices into the USB 3 port. These are ivybridge based dell machines with all of the latest drivers.
#17 shockz
shockz
    Neowinian Senior
  • OS: Windows 8
  • Phone: iPhone 5
Posted 24 December 2012 - 18:02
Thank you, Firey. So I am correct.
There are instances where 32-bit drivers are incompatible with 64-bit OS. A lot of instances actually. So no, you're not correct. Vista 64-bit drivers can also be flakey on 7/8.
#18 Mindovermaster
Mindovermaster
    Neowinian Senior
  • Tech Issues Solved: 14
  • OS: Debian Jessie
  • Phone: Samsung Galaxy SIII
Posted 24 December 2012 - 23:30
Yes, they "can be", Shockz. It's a base on base case. They sometimes work, when other times it can't. Don't call a maybe as a won't.
#19 Lord Method Man
Lord Method Man
    Banned
Posted 24 December 2012 - 23:37
Actually its most instances. Installing 32-bit drivers on a 64-bit system is NEVER good advice.
#20 Mindovermaster
Mindovermaster
    Neowinian Senior
  • OS: Debian Jessie
Posted 24 December 2012 - 23:44
But when you are left with no choice, that is your last chance in seeing any improvement. It works or it doesn't, not like it's going to blow up.
