Jump to content
  • Please log in to reply
53 replies to this topic
#46 Slipdisc210
Slipdisc210
    Neowinian Metallurgist
Posted 30 December 2012 - 12:48
Most systems don't post unless there is a video card running.
Wrong, most will indeed post with ot without a vid card. Just guessing or wanting something to be true wont make it happen.
#47 The Teej
The Teej
    Also known as The Tjalian
Posted 01 January 2013 - 01:19
Check digikey, match up the farad rating and be sure that it's voltage rating is equal or higher and,if possible, look for a low ESR one. The spacing looks cramped so be sure to check the data sheet to be sure it'll fit in the existing footprint.
Pretty much this - this is true for all capacitors. As a matter of fact - the voltage rating doesn't really have a maximum. Although in my experience, the higher the voltage, the bigger the cap - so this does matter within reason :laugh:
#48 DigitalFamilyMember
DigitalFamilyMember
    Neowinian
Posted 01 January 2013 - 01:52
That's normal with old PCs; best to get a new one ;)
My vista laptop sucks as well :/ mehh thats why i use the ipad more :p
#49 pack34
pack34
    Professional Electron Wrangler
Posted 01 January 2013 - 02:09
just like inductors, the max voltage/amperage isn't exact. The component may work at 50v even though it's rated at 35v but the lifespan will suffer.
Just be glad the faulty component just had two leads. I had to swap out an 8-SIP package once, not fun.
Cheap electrolytic caps tend to fail. If you know what you're doing, 30cents and 15 seconds, you're back on business.
#50 The Teej
The Teej
Posted 01 January 2013 - 12:56
Oh, fair enough! The more you know. Cheers!
#51 shockz
shockz
    Neowinian Senior
  • Tech Issues Solved: 1
  • OS: Windows 8
  • Phone: iPhone 5
Posted 02 January 2013 - 02:46
Nope, not most. And the ones that do typically are servers. I could go grab a dell off a shelf right now, pull the card, and it won't post. Unless the machine has onboard graphics you're going to have issues getting it to post.
#52 OP Elliot B.
Elliot B.
    Over 13 years on Neowin
  • Tech Issues Solved: 4
  • OS: Windows 10
  • Phone: Samsung Galaxy S5
Posted 02 January 2013 - 07:14
There might be an upset in RAM or RAM slot. Replace the RAM in another slot and try.
Tried that.
As I said earlier in the topic, the system only booted normally when the video card was removed, so it's most likely the culprit - especially considering the two popped capacitors :)
#53 OP Elliot B.
Elliot B.
  • OS: Windows 10
Posted 07 January 2013 - 10:18
Replaced the capacitors, didn't work. The fans did function normally now, but still no display.
Bought a new AMD Radeon HD5450 PCI Express card, still constantly spinning fans.
I have unplugged everything from the system apart from the PSU, and the fans only stop spinning when the PCI Express port is empty.
I could try a second-hand PCI (non Express) card from eBay, but I don't know if I can be bothered.
#54 +Brando212
Brando212
    Neowinian Senior
  • Tech Issues Solved: 19
  • OS: Windows 8.1
  • Phone: Sony Xperia ZL, Nokia Lumia 925
Posted 08 January 2013 - 18:54
i guess that's a sign that's it not worth it and it's time to upgrade
