Bryan000 Posted January 22, 2002 Share Posted January 22, 2002 Here is a problem that I am having. Maybe someone here can help... Okay. My Windows XP box freezes completely anytime a webpages uses an embedded Windows Media Player 6.4. (the one located at C:Program FilesWindows Media Playermplayer2.exe ) When I say freeze... I mean, I can't move my mouse, I can't use ctrl+alt+del, I can't do anything, it locks up. I am forced to do a power-off reboot. I can open Windows Media Player 6.4 and play files, but it will freeze if say, I go to a website say for example, ifilm.com and try to play a windows media file. The site will open a small IE window that has windows media player 6 inside of it, and then, it freezes. :( This has happened consistently every single time that a site (not just iflm.com, ANY site) that calls for WMP6 to play files. So far I have avoided this by (obviously) avoiding sites or links that will launch WMP6 or that I think may launch it. Because of this... I am almost forced to boycott the WMP format when streaming is concerned because I have no other choice (some of you may say this is a GOOD thing, heh). I do not have this problem with WMP8. I can not delete WMP6 (I have tried, Windows will recreate the .exe) I DO NOT have WMP6 associated with any file types (they are all assigned to WMP8 or other programs) So, my question is, has anyone experienced this problem? And does anyone know a possible solution? A short rundown of my system specs... AMD Athlon 800mhz Microsoft Windows XP Pro (installed using "clean" install not upgrade, on a formated fat32 drive) 16mb agp NVIDIA TNT2 (latest drivers from nvidia.com, problem has occured with other drivers though, I don't feel this is related) motherboard: unknown :( 128mb sdram Thank you! Link to comment Share on other sites More sharing options...
Bryan000 Posted January 22, 2002 Author Share Posted January 22, 2002 bump Any and all advice is appreciated! :) Link to comment Share on other sites More sharing options...
Dessimat0r Posted January 22, 2002 Share Posted January 22, 2002 use wmp 8.0 you are on windows xp, arent you? :) Link to comment Share on other sites More sharing options...
mmr2001 Posted January 22, 2002 Share Posted January 22, 2002 right clik media player 6.4 go to properties select compatibility select win98 under compatiblity click ok. hope this fixes your problem!!! ;) :sleeping: :( :knocked: Link to comment Share on other sites More sharing options...
Bryan000 Posted January 29, 2002 Author Share Posted January 29, 2002 Originally posted by Dessimat0r use wmp 8.0 you are on windows xp, arent you? :) Well, yes I am on XP. And I would use 8 but sometimes you have no choice! Since WMP8 can't imbedd itself into a webpage for some reason, XP still has WMP6.4 for that. I think this is rather stupid actually... but, not much I can do about it.and mmr2001 I will try your advice, I'm willing to try anything at this point ^_^ ****update**** I tried setting wmp6.4 in compatibility mode but I can't. the options are greyed out. I guess this is a tell-tale sign that MS does not intend for it to be ran in compatibility mode, and is a special version of 6.4 to run on XP :) for reference, here is the version number: 6.4.9.1120 Link to comment Share on other sites More sharing options...
Silvorgold Posted January 29, 2002 Share Posted January 29, 2002 strange :- never knew media player 6 ever crashed lol Link to comment Share on other sites More sharing options...
Xcalibur Posted January 29, 2002 Share Posted January 29, 2002 when all else fails.. reinstall windows! i never bother to try and fix it if cant fix it in an hour. Link to comment Share on other sites More sharing options...
Silvorgold Posted January 29, 2002 Share Posted January 29, 2002 if its a software problem i just uninstall it...cept the darn integrated stuff...then if i cant fix those proggiez, i just use alternatives, like when ie6 didnt work properly due to a virus that was on my comp for a few hrs, i had to use mozilla in the mean time due to moving files to cd.... Link to comment Share on other sites More sharing options...
