Jump to content
Will a Sound Card REALLY Improve Quality?
  • Please log in to reply
42 replies to this topic
#31 Riva
Riva
    Neowinian Senior
  • Tech Issues Solved: 2
Posted 05 December 2013 - 17:28
I'm using Asus Xonar DX and it sounds better on my speakers then on-board. I do have an inexpensive Logitech 5.1 Speaker System.
I'm connected via standard analogue speaker connector, not optical / digital.
It also sounded better (to me) compared to the Creative Labs X-Fi titanum I had on there before as well.
You can also test you sound card with this program
http://audio.rightma...index_new.shtml
using a male to male wired connection.
Yeap I used to own the DX as well but fall in love with the ROG one. I have a ###### 5.1 Logitech myself for the past 5-6 years
#32 ryoohki
ryoohki
    Neowinian
Posted 05 December 2013 - 17:31
Depand on if you use PC audio output. For headphone i got a little Creative Labs XFI HD USB and the sound quality is amazing.  For SPDIF, it's you're receiver that doing the job, same with HDMI...
#33 PGHammer
PGHammer
    Neowinian Senior
  • Tech Issues Solved: 1
  • OS: Windows 8 Pro with Media Center x64
Posted 05 December 2013 - 17:37
I've tried adding a sound card and it was not worth the effort or money spent on it.  I removed it and returned to the onboard sound, works very well for me.  Save your cash for something else.
hamslammer - do you use HDMI or another entirely-digital path from the PC to your ears?  If so, then your logic makes sense.  (This includes optical-out to A/V, USB headphones, HDMI, etc.)
However, if you use an analog path (analog speakers OR headphones) or connect to the speaker OR headphone jacks of your motherboard, then you are shortchanging yourself, simply due to the sloppiness of the D-A conversion mechanism built in to motherboards.
The digital/analog audio conversion path has gotten better on motherboards - that much I won't dispute.  However, it is still not as well done as most discrete sound cards - even the bottom end from Creative.
Basically, which is better is path-dependent.
#34 PGHammer
PGHammer
    Neowinian Senior
Posted 05 December 2013 - 17:46
I have nothing against HDMI from a GPU - my AMD HD5450 had a full-size HDMI output to my display, which I used for both video and audio.
UNfortunately, when I swapped in my current nVidia GTX550Ti, the HDMI port on the newer GPU was mini-HDMI - not full-sized.  (And an adapter was NOT included.  Yeesh.)
And mini-HDMI to standard HDMI adapters are more expensive than any other sort of adapters for HDMI - or, more importantly, more expensive than a PCI Express or USB discrete audio solution from Creative. (My refurbished Recon3D Fatality Professional was all of $45 - including tax. And it decidedly is NOT PCI - it uses the topmost PCI Express x1 slot - above my GPU - which means it interferes with exactly nothing - in terms of either interrupts or airflow, AND it lacks the 4GB address hardware flaw that the PCI-based X-Fi suffers from.  All win, and without BOHICA.)
#35 AR556
AR556
    Neowinian Senior
Posted 05 December 2013 - 17:48
I have an ASUS ROG Xonar Phoebus and yes the quality is significantly better than the onboard realtek 7.1 with all the enhancements.
The other benefit of the ASUS sound cards is that they truly offload audio processing to the audio card which means less CPU utilisation.
Creative have lost the plot with their drivers since the audio stack in windows was re-written back in vista and audio drivers no longer execute in kernel memory space causing performance issue and playback issues (like a scratched CD). They also fail to release compatible audio drivers on time for new versions of Windows.
So you're pretty happy with the Asus cards? I've been thinking about getting one simply to get rid of the damned "sound card out of range" B.S. error I keep getting with VMWARE/Realtek audio and Linux guests. Pisses me off to no end. There are work arounds on the net, but Realtek's audio options are missing the required settings or the Linux guest doesn't have the audio setting needed on its own end.
#36 T3X4S
T3X4S
    Neowinian Senior
  • Tech Issues Solved: 3
Posted 05 December 2013 - 17:56
Im not sure if this has been mentioned - but if one is truly concerned about audio quality,  listening to MP3 on $80 speakers makes any sound card/onboard discussion completely moot.
So many times I will hear people ramble on about this topic, then top it off with "I have it plugged into a Creative Labs ....." which is some $100 crap speakers.
#37 Riva
Riva
    Neowinian Senior
Posted 05 December 2013 - 17:59
So you're pretty happy with the Asus cards? I've been thinking about getting one simply to get rid of the damned "sound card out of range" B.S. error I keep getting with VMWARE/Realtek audio and Linux guests. ****es me off to no end. There are work arounds on the net, but Realtek's audio options are missing the required settings or the Linux guest doesn't have the audio setting needed on its own end.
Yes I am very happy with the ASUS range since 2008.
#38 Phouchg
Phouchg
    has stopped responding
  • Tech Issues Solved: 9
Posted 05 December 2013 - 18:03
This all probably boils down to a point that audio quality is subjective and hard to grade. Different equipment sounds different to different set of ears. A purist (probably a characteristic of me, lately) would prefer the most accurate possible representation of the original recording, even if it sounds "flat", "inexpressive" etc.. Others would rather have some coloration of highs (often confused with overamplification of minute details). Some might prefer deep bass even when it isn't there. And there's the special sort of folks with their tube amps, which distort... in a pleasing way. And, let's be honest, most of us just can't hear shhhhh...
Watxch a movie with DTS sound. drop out to the MC software menu and if it has nav sounds, they're not going to be DTS or DD and the computer will send another audio stream, causing the receiver to switch and you get sound drop and a pop. sometimes you will get a pop for every nav sounds and the software/windows insist on switching back to DTS or DD all the time.  Same if windows for some reason decides to give you a ding or something in the background. or in any other situation where you can switch between different times of audio streams(more often than you think in a htpc)
I see. So a dedicated audio processor fixes this or is it a problem inherent to the protocol and receivers?
#39 HawkMan
HawkMan
    Neowinian Senior
  • Tech Issues Solved: 4
  • Phone: Noka Lumia 1020
Posted 05 December 2013 - 18:30
Some of the dedicated sound cards support DD Live/DTS interactive(it might be DDi and DTSLive, I don't remember). Where the sound cards will take ALL the sounds the computer makes, wrap them together and send them back out as DTS or DD, making sure the receiver never has to change stream, stopping all drops and pops as it constantly gets a DD or DTS stream.
#40 Phouchg
Phouchg
Posted 05 December 2013 - 19:15
Ok, then I reckon the problem indeed is there, even though it probably comes with the protocol and the receivers generally being unable to switch seamlessly (which is a shame, given that receivers are usually serious piece of kit regardless of their standing), and a sound card with the mentioned features provides a band-aid, a pretty good one, though.
#41 PGHammer
PGHammer
    Neowinian Senior
Posted 06 December 2013 - 21:53
Most PCI Express (and quite a number of midrange or above PCI) sound cards, and especially those with DSPs, support both protocols - the original PCI-bus X-Fi (and all their successors) is a prime example.  There HAVE been A/V receivers that could seamlessly switch-on-detection; however, they weren't cheap (Sony's ES series and Pioneer's Elite series, for example) - it was while ear-testing both series of receivers back in the Windows 9x era that I discovered the presence of Dolby Digital in FM (as in radio, and as in outside of simulcasts).
#42 OP Sir Topham Hatt
Sir Topham Hatt
    A Very Talented Individual
Posted 07 December 2013 - 09:39
So leading on from this, if my motherboard has optical out, would this be best to use instead of the three cables (for surround sound)?
The only advantage would be to cut down on the cable mess behind the PC but I don't know what would be better.
Thanks
#43 HawkMan
HawkMan
    Neowinian Senior
Posted 07 December 2013 - 09:46
yes. optical out would prevent signal noise and would give digital all the way.
