Jump to content
Remote Desktop Connection help
  • Please log in to reply
20 replies to this topic
#16 OP Scraggles
Scraggles
    RootLeak
Posted 23 May 2014 - 15:26
So where is it you are seeing RDP FPS?
How do you get this info, I show on my connection only this.
So with TV, again I don't show any FPS info - are you trying to watch videos or something over these connections?
Is there some command you are doing that I am not aware of to show this FPS info?
Fraps shows it for me.
#17 +BudMan
BudMan
    Neowinian Senior
  • Tech Issues Solved: 113
  • OS: Win7, Vista, 2k3, 2k8, XP, Linux, FreeBSD, OSX, etc. etc.
Posted 23 May 2014 - 15:44
Ok I don't understand how that is relevant for a remote desktop session to be honest.
I installed fraps, fired up remote desktop and it showed 1 fps when not doing anything.. And then if I moved a window or something it went up.. FPS might be a useful measurement if watching a video. But working with a desktop unless your moving something around its pretty much meaningless -- its a static picture, so fps would be 0 ;)
#18 OP Scraggles
Scraggles
    RootLeak
Posted 23 May 2014 - 15:46
to show 0fps the screen would have to be off. A static picture is 1fps by default :)
#19 +BudMan
BudMan
    Neowinian Senior
Posted 23 May 2014 - 16:16
Ok - but you get my point ;)
So again what are you using for your comparison between TV and RDP.. Are you connecting from outside, or just lan? TV has lan option for example - there are all kinds of display and quality tweaks for both systems. For example you say stuff teleports - on my RDP session, which I have set to automatic when I move window I get a frame showing the window to where I will move it.
While on TV I see the window contents as I move it about the screen.
If I manually set RDP settings then I can pick to have it show the contents of the window as I move it
#20 Atlanowl
Atlanowl
    Neowinian
Posted 27 May 2014 - 19:11
How would I remotely connect to a pc using Remote Desktop Connection from outside of the network?
For example, the address inside the network is "192.168.1.100" and that is all I need to enter for the pc name. How would I connect to that pc from a friends house for example?
There was a similar discussion on Spiceworks community http://community.spi...or-remote-sites that might be helpful.
#21 frett
frett
    Neowinian
Posted 06 June 2014 - 15:03
Not only can you setup custom RDP ports, you can set up a different one for each PC on your network using port forwarding in your router.
