ACTIONpack Posted November 8, 2015 Share Posted November 8, 2015 I own a Samsung Galaxy TabPro 8.4 wifi only. When I got it last year, I really like it didn't have any issues until 6 to 8 months ago. When the OS would crash for no reason and keep crash at start up. I found out after playing Tapped Out, that it wipped out my battery until turn off the tablet to charge it. It then should I had 60% battery instead of 5%. I ha r try to reinstall OS over 10 times in the past 8 months but still have this issue. Would like to know if anyone had this issue. I really want to replace it for a Samsung Galaxy Tab S2 but if im going to have this issue again with an android tablet then I would reason jump to an iPad Air 2. Link to comment Share on other sites More sharing options...
LoneWolfMage Posted November 9, 2015 Share Posted November 9, 2015 ACTIONpak ~ IF i am remembering correctly there WAS an issue with ..a particular update with Lollipop Android os where something in it was causing the drain the battery prematurely.. I also believe that was fixed with a recent Android os update. I had this issue as well with my Nexus ( first gen) tablet .. then when I got the OTA update .. it fixed the issue.. what you MAY/COULD do is a factory reset and then let it to the the OTA updates till fully updated ( I had to to this with my Nexus and it solved the issue) yeah its a PITA but it solved the issue real quick .. Best of luck . ~Lonewolf Link to comment Share on other sites More sharing options...
ACTIONpack Posted November 9, 2015 Author Share Posted November 9, 2015 ACTIONpak ~ IF i am remembering correctly there WAS an issue with ..a particular update with Lollipop Android os where something in it was causing the drain the battery prematurely.. I also believe that was fixed with a recent Android os update. I had this issue as well with my Nexus ( first gen) tablet .. then when I got the OTA update .. it fixed the issue.. what you MAY/COULD do is a factory reset and then let it to the the OTA updates till fully updated ( I had to to this with my Nexus and it solved the issue) yeah its a PITA but it solved the issue real quick .. Best of luck . ~Lonewolf Samsung hasn't release any update to the OS when it was release. So it's its on 4.4.3 of Android. :-( Link to comment Share on other sites More sharing options...
TAZMINATOR Posted November 9, 2015 Share Posted November 9, 2015 Samsung hasn't release any update to the OS when it was release. So it's its on 4.4.3 of Android. :-( You can root it then install ROM on it... It could solve battery problem. Up to you. Link to comment Share on other sites More sharing options...
