Hellafax Posted February 19, 2002 Share Posted February 19, 2002 Okie dokie -- To get to the Device Manager -- Right click on "My Computer," select "Manage." Select "Device Manager," double click on "IDE/ATA Controllers," then double click on "Primary IDE" -- select "Advanced Settings" If your Primary IDE (Your HDD) is in PIO mode, close the properties dialog, right click on the Primary IDE, and select "Uninstall," then reboot. Good luck, and I hope it helps. Link to comment Share on other sites More sharing options...
GRiM Posted February 19, 2002 Author Share Posted February 19, 2002 Nope, wasn't in PIO mode... Link to comment Share on other sites More sharing options...
Ruciz Posted February 19, 2002 Share Posted February 19, 2002 delete your controller, unplug it from your box and restart. now after your computers restarted plug it back in, and go to "add" select your controller and give it about 10 seconds to install. if it still says not connected, go to the gravis website and look for updates for XP. thats all I can think of, if you already did that. try uninstalling it, then restarting with it not plugged in, then restart again and plug it in while restarting. sometimes that works. Link to comment Share on other sites More sharing options...
