Please Read And Help Me Wixp Problem
Some tiem ago i bougth a new 7200 rpm hard disc so naturely i baked up my files , and the re installed winxp on my new drive , the only problem was that i drag and droped folders such as my document , my pictures , and the desktop , and now i cant read them becouse of the encription mode !!! What can i do some help, i tryed a lot of thing and still no good , any ideas , something tells me im not the first one with this problem
I thinks i was becouse of the option of encripting or protecting my files (user account)
  • 3 weeks later...
use a file synchronizer. check www.download.com and get one and sync the the folders... i don't think it matters and it happened like that wiht me before... there should be a securtiy tab or something when you right click the folders though...
Try to take ownership of the folders. The problem is the SID is different on the backed up folders then the new folders.
??? what how??
How can i take ownership?
what is sid?
If you encrypted those files using XP EFS it think you are screwed! The whole idea of encrypting the files is so that no one else can read them if the HD was stolen or someone got illegal access to your pc. I believe that when you install/reinstall new public key is generated for each installation. Being you encrypted you files with one key (previous install) and then reinstalled XP a new key is generated which isn't the same key that the files were initially encrypted with so now you cannot decrypt your files.
How to take ownership
SID is Security Identifier.
