help help help with linux networking - pleeeaaasse
help! i have tried to install 3 linux distro's on 3 different machines (u call em box's :D) and allways i hit a problem:
normally i can set up networking fine the first time and it works for maybe 3 or 4 days.
then after that it simply stops working.
i havent got a clue why.
oh and its a lan.
i connect to a windowsxp server.
i would use linux if the network would work.
i hope i can fix it.
Ok, first things first:
what distro are you running now?
Do you have you Linux box set with a static IP or DCHP-served IP?
If DCHP, who is serving it? A router? Another PC? Which OS on that PC?
Do you have more than one PC on this home network?
Do they each connect individually to the router?
That's good for starters. :)
