Need help installing a mIRC script
2 answers to this question
    • [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Blocked] "{e2bf9676-5f8f-435c-97eb-11607a5bedf7}"="Share" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Blocked] "{e2bf9676-5f8f-435c-97eb-11607a5bedf7}"="Share" [-HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\ModernSharing] Remove that Share text.
    • Meh could never use the UWP as I use WhatsApp business and it's features are available on the standard. Thos this applies to both windows and macos+ipad versions. So I'm stuck on using web versions for whatever platform.
    • I hardly have issues with my ipad pro 4's faceid while holding it on Portrait
    • Sure, one example: Two computers side by side. Your main system is connected to a sound bar or a high end TV with good audio built in. Your secondary machine is the one you play music, movies, YouTube, check email, etc. on another monitor while you work/play games on your main system. In this case, the main computer converts all audio to Dolby Atmos which goes out to the main TV/soundbar (or your bluetooth/headphones), no matter if it comes from the main machine or the secondary...with no latency issues. And whatever you'd be doing on the secondary computer isn't hitting your main computer's CPU or GPU if, say, gaming some serious FPS or at 4k etc. That's just one home use case for a networked audio solution. I'm sure others can think up more of them.
    • Yeah, I've looked at all of these. Dante is a pro and expensive program, of course. I'm just looking for simple audio/music sharing from one PC/device to another. Voicemeeter is a lovely bit of kit, but the interface is NOT user friendly to set up initially, unless you are an audio engineer who thinks the way the program does. It works though. I just didn't feel the juice was worth the squeeze on that one. The other ones you mention each have problems, like no longer maintained/updated, blocks auto-audio switching on receiving computer from say headphones to HDMI, etc. Spotify does this, but only for music played by Spotify. Multiplicity does this (but isn't free) for all audio on one PC (like you'd want) but hiccups the audio on the source PC if too much CPU is used (so you really can't use a very old PC as a music/video/youtube player). Oh, and because of how the old version (I haven't tried the newly released one because it still has a showstopping bug that's not been addressed) shares the mouse between screens, it interferes (and can crash) video games on the server/main machines, etc. Multiplicity Pro was the best of the normal solutions, however. If the two machines are side by side, you can use analog line out to analog line in, but then you are getting analog noise/problems. It's the simplest and most solution, of course.
      Snake Doc went up a rank
      nobody9 earned a badge
      Ricky Chan earned a badge
      leoniDAM earned a badge
      Ian_ earned a badge
      136
      117
