Just started playing around with Stardocks object dock, and its pretty cool...except that when you turn the start menu off, it kills access to your system tray...i know theres a tray tab in the dock menu thingy, but it has no icons in it...I use the systray a fair bit, so need access to icons hiding down there...
Anyone know how to get this to work? Or if it is impossible, if it will be added soon?
https://www.neowin.net/forum/topic/213817-objectdock-and-system-tray/
