- 0
Help with coding...
Asked by
spiegel,
Recently Browsing 0 members
Posts
By hellowalkman · Posted
TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 is just $135 by Sayan Sen If you’re juggling gaming consoles, 4K streams and a growing roster of smart devices, the TP-Link Archer GXE75 Tri-Band AXE5400 Wi-Fi 6E Gaming Router is a good option to look at right now, considering the device is currently on sale at just $135 (purchase link under the specs table below). The Archer GXE75 promises up to 5.4 Gbps of throughput across three bands: 574 Mbps on 2.4 GHz, 2402 Mbps on 5 GHz and 2402 Mbps on 6 GHz (HE160 channels enabled). A 2.5 Gbps WAN/LAN port pairs with three 1 Gbps LAN ports and a USB 3.0 port for fast file sharing or printer access (purchase link down below). The quad-core CPU and 512 MB of RAM should help to handle multiple streams without bogging down, while MU-MIMO, OFDMA and 1024-QAM improve efficiency when several devices connect simultaneously. The router’s built-in Game Accelerator engine is said to automatically prioritize gaming packets (both wired and wireless), and TP-Link’s GPN (Gamers Private Network) acceleration can reduce packet loss for supported titles. HomeShield security brings firewall protection, device quarantining and parental controls. The technical specifications of the router are given below: Specification Details Wireless Standards IEEE 802.11ax 6 GHz; IEEE 802.11ax/ac/n/a 5 GHz; IEEE 802.11ax/n/g/b 2.4 GHz Wi-Fi Speeds 6 GHz: 2402 Mbps (802.11ax); 5 GHz: 2402 Mbps (802.11ax); 2.4 GHz: 574 Mbps (802.11ax) Spatial Streams 6 streams (tri-band OFDMA/MU-MIMO) Processor 1.7 GHz 64-bit Quad-Core CPU Memory 512 MB high-speed RAM Ethernet Ports 1× 2.5 Gbps WAN/LAN; 1× 1 Gbps WAN/LAN; 3× 1 Gbps LAN USB 1× USB 3.0 SuperSpeed port (up to 10× faster than USB 2.0) Antennas 4× high-performance external antennas with Beamforming Buttons Power On/Off; Reset; WPS/Wi-Fi; LED On/Off Working Modes Router Mode; Access Point Mode Security WPA, WPA2, WPA3, WPA/WPA2-Enterprise; SPI firewall; Access Control; IP/MAC binding; Application-layer gateway; HomeShield security suite VPN OpenVPN, PPTP, L2TP (server & client); WireGuard (server & client) Software & Services IPv4/IPv6; TP-Link HomeShield; EasyMesh; Parental controls; QoS by device; WAN types (Dynamic IP, Static IP, PPPoE, PPTP, L2TP); DDNS (TP-Link, NO-IP, DynDNS); auto firmware updates Gaming Features Game QoS boost; gaming-port priority; Gamers Private Network acceleration; game-port forwarding; real-time game panel with stats & RGB control Operating Environment 0 °C – 40 °C; 10 %– 90 % non-condensing humidity Get the TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 at the link below: TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 | EasyMesh, HomeShield: $159.99 + $25 off with coupon => $134.99 (Sold and Shipped by Amazon US This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases. -
By SnyPer456 · Posted
Oh no... here we go again. Tha same sh*t that happaned to Mail & Calendar... -
By excalpius · Posted
I too have worked with pro gear for decades and so I found the interface to be unintuitive from both the pro and casual side (a rare "accomplishment" by what are obviously otherwise skilled coders, hehe). I eventually got it to work, thanks for offering, but I found other compatibility issues with my own use case, so I just dropped it entirely. Right now, I just use an analog line out/line in approach which works as expected across all usage scenarios. With both machines on the same power block/outlet, I'm not getting any analog hum or hiss. My next step will be to try the updated Multiplicity 4 when a bug, addressing this very issue unfortunately, is resolved. Knowing Stardock, that could be tomorrow or five years from now, so I check back every few months to see it it's fixed and I want to upgrade. Again, thanks for offering to help. -
By Files App · Posted
We recognize that performance can use some improvements, and we continue to work on improving it. However, it's worth noting that massive performance improvements don't happen overnight, they take a lot of work and effort, and in most cases, the improvements are more noticeable when you compare across several updates. That said, Files is open-source and everyone is invited to help with these efforts 🙂
Recent Achievements
Snake Doc went up a rank
nobody9 earned a badge
Ricky Chan earned a badge
leoniDAM earned a badge
Ian_ earned a badge
Popular Contributors
Tell a friend
spiegel
This is my blog the problem with it is i would like the text window to be placed on the right , where the white space is. any help would be appreciated.
here's the code.
1st part.
2nd part
thanks in advance
https://www.neowin.net/forum/topic/266920-help-with-coding/Share on other sites
1 answer to this question
