im working on a project in access and i want to create a search button. i found a ready code but when im running the search button im getting this error messase
This error occurs when an event has failed to run because Microsoft Office Access cannot evaluate the location of the logic for the event. For example, if the OnOpen property of a form is set to =[Field], this error occurs because Access expects a macro or event name to run when the event is fired.
does any one knows why? here the search code . name of the label is txtSearch and the name of the button is cmdSearch
Option Compare Database
Private Sub cmdSearch_Click()
Dim struserRef As String
Dim strSearch As String
'Check txtSearch for Null value or Nill Entry first.
If IsNull(Me![txtSearch]) Or (Me![txtSearch]) = "" Then
MsgBox "Parakalo isagete timi!", vbOKOnly, "Invalid Search Criterion!"
Me![txtSearch].SetFocus
Exit Sub
End If
'Performs the search using value entered into txtSearch
'and evaluates this against values in struserID
DoCmd.ShowAllRecords
DoCmd.GoToControl ("user_id")
DoCmd.FindRecord Me!txtSearch
arithos_tautotitas.SetFocus
struserRef = auser_id.Text
txtSearch.SetFocus
strSearch = txtSearch.Text
'If matching record found sets focus in struserID and shows msgbox
'and clears search control
If struserRef = strSearch Then
MsgBox "Match Found For: " & strSearch, , "Congratulations!"
user_id.SetFocus
txtSearch = ""
'If value not found sets focus back to txtSearch and shows msgbox
Else
MsgBox "Match Not Found For: " & strSearch & " - Please Try Again.", _
txtSearch.SetFocus
End If
End Sub
_g3o_
Option Compare Database Private Sub cmdSearch_Click() Dim struserRef As String Dim strSearch As String 'Check txtSearch for Null value or Nill Entry first. If IsNull(Me![txtSearch]) Or (Me![txtSearch]) = "" Then MsgBox "Parakalo isagete timi!", vbOKOnly, "Invalid Search Criterion!" Me![txtSearch].SetFocus Exit Sub End If '--------------------------------------------------------------- 'Performs the search using value entered into txtSearch 'and evaluates this against values in struserID DoCmd.ShowAllRecords DoCmd.GoToControl ("user_id") DoCmd.FindRecord Me!txtSearch arithos_tautotitas.SetFocus struserRef = auser_id.Text txtSearch.SetFocus strSearch = txtSearch.Text 'If matching record found sets focus in struserID and shows msgbox 'and clears search control If struserRef = strSearch Then MsgBox "Match Found For: " & strSearch, , "Congratulations!" user_id.SetFocus txtSearch = "" 'If value not found sets focus back to txtSearch and shows msgbox Else MsgBox "Match Not Found For: " & strSearch & " - Please Try Again.", _ , "Invalid Search Criterion!" txtSearch.SetFocus End If End Subthank u
1 answer to this question
