burnsflipper Posted December 26, 2001 Share Posted December 26, 2001 Hello there people, I'm requesting for your help because I have a problem, the situation is as follows: I have NTFS on XP Pro, with 2 users, both administrators, on the first user I have installed Morpheus and I can use it without problems, but when I switch to the other user, I can't even see the icon of morpheus, it appears as a normal ms-dos application, and when I try to open it it tells me that the program does not exist or that maybe I have some restrictions :( Hope that somebody can help me, and thank u all in advance Link to comment Share on other sites More sharing options...
nekrosoft13 Posted December 26, 2001 Share Posted December 26, 2001 install it on you other name too Link to comment Share on other sites More sharing options...
Steven Posted December 27, 2001 Share Posted December 27, 2001 Must Be Supported by The Program, User Switching Is New To The Windows OS, and programs need to be modified to work with this feature properly. Your program may only allow one of itself in memory at one time, and not compliant YET with virtual terminals that xp offers. i saw this on some Microsoft Thing. Link to comment Share on other sites More sharing options...
configure Veteran Posted December 27, 2001 Veteran Share Posted December 27, 2001 In addition to xStainDx's post, try "logoff" and login as another admin account, the one with the problem and try access Morpheus.. :) Link to comment Share on other sites More sharing options...
AngelDeath Posted December 27, 2001 Share Posted December 27, 2001 Also check under the All Users folder in the Documents and Settings Folder, some programs have a tendency of installing themselves in the folder of the current on-line user, and not under all users. if thats the case, then move the entire folder into the All Users folder and see if that may help you to be able to access the program from another name. Link to comment Share on other sites More sharing options...
