There are many great features available to you once you register at Neowin, including:
  • Richer content, access to many features that are disabled for guests like commenting on the front page
  • Access to a great community, with a massive database of experience on hard & software issues, gaming and recreational activities, and more
  • Access to the Neowin IRC - you could make a friend from across the world and talk to them live
  • Access to Neowin contests & subscription offers and forums that are not open to guests/li>
  • It's simple, and FREE! · Register here
Audio from GTX 280 help! Cable needs finding...
 Share
Hi all
Any help would be great?.I want to run sound through my GTX 280 so it can go straight to my TV HDMI port. So it looks like I need to connect a SPDIF cable to the graphics card that looks like picture below ?
The problem is my Asus Xonar DX 7.1 PCI-Express Sound Card does not have a internal SPDIF out?..so I think need the cable below which is a external to internal SDIF cable?I know about these as I got one with an old HDMI MSI graphics card but that one is in use in media centre??The cable at top right...
So basically I need help finding this cable or another option?..I really can?t find the cable anywhere?.please HELP.
Thanks a lot
P.S Im from UK
This is best I could find.
http://www.frontx.com/pro/p1062_030.html
Yeah I found that one but it seems to have a 3 pin header rather then the 2 I need.....thanks for looking
Does your TV have a Audio in?
Ok this might work?
http://www.lindy.co.uk/35mm-mono-jack-to-rca-phono-female-adapter/35513.html
Yeah I could just use a 3.5 cable but would not be digital and its an extra cable rather then it via hdmi....
 Share
