Angel of Death Posted August 5, 2003 Share Posted August 5, 2003 I have some trouble setting up a simple home network. (Note that I don't have a cable/dsl connection) What I want to do is share files between my desktop and laptop. For my desktop, I have the network port connected to NETGEAR Cable/DSL Wireless Router (MR814). For my laptop, I have a NETGEAR 802.11b Wireless PC Card. I ran the Network Setup Wizard on both machines. On my desktop, I ran it fine. On my laptop, I had to ignore the network cable is unplug option (cause i want to share files through the wireless card). What do I have to do? Thanks. Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 Check out these Two Threads: https://www.neowin.net/forum/index.php?act=...ST&f=32&t=95703 https://www.neowin.net/forum/index.php?act=...ST&f=32&t=95505 :) Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 I read it and I'm still confused. I think the problem I'm having is creating a LAN network with my card to my router. I'm not sure how to fix that. (yea, i can connect to it fine, but LAN network is not connected.) Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 How many computers are their connected from the router? What are wireless and what are wired? Can you ping the machines? Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 The desktop is connected to the router with a network cable. The laptop is connected to the router through a wireless card. I did ipconfig on both machines and for the desktop, i got the IP of 192.168.0.2. for the laptop, i got 192.168.0.3. I typed out "ping 192.168.0.2" on my laptop and got this: Pinging 192.168.0.2 with 32 bytes of data: Request timed out. Request timed out. Request timed out. Request timed out. Ping statistics for 192.168.0.2: Pactkets: Sent = 4, Recieved = 0, Lost = 4 (100% loss), Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 Now try it the other way around. Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 I get the same message. Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 do any of them have a Firewall? are you using Windows XP on both? The both have an internet connection right? Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 They both run Nortan Internet Security 2003 and Windows XP. They both connect to the internet through dial up (I have no cable/dsl connection). I tried disabling on both and ran the ping again. This time, I got: Pinging 192.168.0.2 with 32 bytes of data: Reply from 192.168.0.2: bytes=32 time=3ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Ping statistics for 192.168.0.2: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 2ms, Maximum 3ms, Average = 2ms Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 They both run Nortan Internet Security 2003 and Windows XP. They both connect to the internet through dial up (I have no cable/dsl connection). I tried disabling on both and ran the ping again. This time, I got: Pinging 192.168.0.2 with 32 bytes of data: Reply from 192.168.0.2: bytes=32 time=3ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Reply from 192.168.0.2: bytes=32 time=2ms TTL=128 Ping statistics for 192.168.0.2: ? ?Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: ? ?Minimum = 2ms, Maximum 3ms, Average = 2ms Awsome! I would suggest removing your firewall now that you have a Router, It has a built in firewall. The NIS2003 is stopping the two pc's from talking to one another. Once you sort out that, then all you need to do is share folders. Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 Alright, I've picked out a few folders from each computer to share. (it has a little hand picture on the bottom of the icon so i'm sure i did it right). I'm in the Network Connections folders right now. How can I see the folders I'm sharing? Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 Ok, I found it. Thanks a lot for all your help! I appreciate it! :) :) :) Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 Just wondering...is there anyway connect to the internet with my desktop through dial up, and share that connection with my laptop? (i kno i kno, slow connection, but i was just curious) Link to comment Share on other sites More sharing options...
Steven Posted August 5, 2003 Share Posted August 5, 2003 Just wondering...is there anyway connect to the internet with my desktop through dial up, and share that connection with my laptop? (i kno i kno, slow connection, but i was just curious) not sure why you would want/need too you already have a Cable/DSL Connection Via Wireless Router. :unsure: If you wanted to, just use Internet Connection Sharing. Link to comment Share on other sites More sharing options...
Angel of Death Posted August 5, 2003 Author Share Posted August 5, 2003 (edited) Errm...'cause I told ya, *don't have cable/dsl connection* :( I'll get it soon tho. About using internet connection sharing. Where and how do I do that? Edited August 5, 2003 by Angel of Death Link to comment Share on other sites More sharing options...
