If you're in the market for a battery pack, then we have a few great offers available to you. Save up to 71% with one of the deals below from the Gear + Gadgets section over on the Neowin Deals store.
71% off the Power Castle 26000mAh External Battery
This monstrous external battery is dubbed the Power Castle for good reason. The Versailles of batteries, it packs a 26000mAh capacity, meaning you can charge most phones 12 times and most tablets 2-3 times on a single charge. This massive juice pack will even power your laptop—and it does it all at optimum speeds in brushed-aluminum elegance.
- Sturdy & durable with brushed aluminum alloy finish
- Reliable & secure charging
- Conserves battery power when not in use
- Achieves superb heat dissipation
- Protects against wear & abrasion
- Works with most tablet PCs & virtually all USB-compliant devices on the market
- Perfect for travel
The Power Castle 26000mAh External Battery usually costs $300, but can now be picked up for only $84,99 on the Neowin Deals store.
70% off the URGE 6000mAh Power Bank
Never worry about your phone, tablet or e-reader dying while you’re on the go with this ultra-portable external battery. Not looking to add more weight to your load? The URGE is perfectly sized to give you maximum power, and minimal nuisance.
- Charge your devices in the dark with the included LED flashlight
- Power 2 gadgets simultaneously w/ the dual-USB output
- Take it on the road (super lightweight design!)
- Use with all your USB-powered devices
The URGE 6000mAh Power Bank usually costs $50, but can now be picked up for only $14,99 on the Neowin Deals store.
40% off the ZeroLemon SolarJuice 10000mAh Battery pack
The SolarJuice battery pack can power up your gadgets in the most unexpected places, and it's extremely compact. SolarJuice charges up at home like your average battery pack, but also lets you add extra juice on-the-go using its built-in solar panel—so you’ll never be left unplugged from the digital world.
- Simultaneously charges 2 devices at once
- Rain-resistant, shockproof & environmentally friendly
- Anti-explosion, lightweight, compact & reliable
- Includes a top grade-A cell, built-in 10000mAh lithium polymer battery
- Comprised of 2 total outputs: 2A fast-charging for mobile devices + 1A charging for smartphones
- Allows casual solar charging via a powerful 1.2W monocrystalline solar panel
- Boasts an ultra-long battery life; recharge the SolarJuice 1000+ times
- Use in the dark w/ built-in LED flashlight
The ZeroLemon SolarJuice 10000mAh Battery pack usually costs $50, but can now be picked up for only $29,99 on the Neowin Deals store.
All of the above deals are time limited, and you can even get an additional $10 credit by sharing any of the above deals with friends below the Add to cart button on the respective deals pages.
If this offer doesn't interest you, why not check out our pick your own Premium Android giveaway, and other giveaways on the Neowin Deals web site? There's also a bunch of freebies you can check out here.
Disclosure: These are StackCommerce deals in partnership with Neowin.
-1 Comments - Add comment
