Earlier today, we covered the Acer Nitro XV2 1440p 300Hz IPS monitor, which is an excellent deal at just around $300. If, however, you are looking for something better and are willing to spend more, then Samsung has Odyssey G6 1440p 500Hz QD-OLED (the world"s first) for just over $600, which is nearly $300 less than its MSRP (purchase link under the specs table down below).
Compared to the Nitro XV2, you are obviously going to get much better picture quality on the Odyssey G6 due to it being QD-OLED and also the significantly higher color gamut coverage and accuracy. And it is very fast too, with its 500 Hz refresh rate rating and 0.03ms(GTG) response times. The monitor also supports AMD FreeSync Premium Pro, and that means features like LFC (low framerate compensation) will be there to aid in case your framerate falls below the adaptive sync range. Overall, it seems like a great product for the price.
The technical specifications of the 27 Inch Odyssey OLED G6 G60SF are given in the table below:
| Specification | Value |
| Model Code | LS27FG602SNXZA / LS27FG600SNXZA (region-specific) |
| Panel Type | QD‑OLED (Quantum Dot OLED) |
| Resolution | QHD (2560 × 1440) |
| Refresh Rate | Up to 500 Hz |
| Response Time | 0.03 ms (GtG) |
| Brightness (Typical) | 250 nits |
| HDR | VESA DisplayHDR True Black 400 certified |
| Contrast Ratio | 1,500,000:1 |
| Color Coverage | 99% DCI‑P3 (typical), 1M colors |
| Viewing Angle | 178° (H) / 178° (V) |
| Anti‑Glare | Glare-free technology (54% less glossy than conventional AR film) |
| Inputs | 2 × HDMI 2.1 1 × DisplayPort 1.4 2 × USB 3.0 Hub 1 × Headphone Out |
| Audio | Headphone out with DTS Headphone:X support |
| Stand Adjustments | Height, Tilt, Swivel, Pivot |
| VESA Mount | 100 × 100 mm |
Get it at the link below:
Samsung 27" Odyssey Gaming Monitor QHD 2560x1440 500Hz OLED | LS27FG602SNXZA: $609.99 (Shipped and Sold by Amazon Woot US) (MSRP: $999.99)
As an Amazon Associate and Woot affiliate partner, we earn from qualifying purchases.
