Alienware 34 240Hz QD-OLED Monitor: A premium ultrawide for serious gamers - save $100!
Are you a serious gamer looking to save money on a monitor upgrade? If so, check out this deal on the Alienware 34 240Hz QD-OLED Gaming Monitor (AW3425DW), which is discounted by 13% from $799.99 to just $699.99. This ultrawide monitor features a 3,440 x 1,440 pixel display and the screen is curved for added immersion.
Two features that will stand out to competitive gamers are the 240Hz refresh rate and 0.03ms GtG response time which will minimize any lagging from input to display, making you a more lethal player.
Why QD-OLED matters for gamers and creators
This Alienware uses QD-OLED (Quantum Dot Organic Light Emitting Diode) technology which combines OLED’s self-emitting LEDs with the color-enhancing capabilities of quantum dots. This results in higher brightness, a wider color gamut, deeper blacks, and wide viewing angles.
With the 1800R curve built into this display, whatever you’re immersed in will wrap around, making your games more absorbing, potentially reducing other distractions. There is also VESA DisplayHDR TrueBlack 400 certification and 1,000 nits peak HDR brightness on this display.
Gamers using this monitor will be able to get the best quality picture from this monitor to improve the experience and their competitiveness. It’s also good for creators who want to edit images and videos as they will see the content they"re editing in the best ways possible, so they can be totally sure it’s ready for publication.
Design, connectivity, and user experience
The Alienware 34 uses an updated Interstellar Indigo design which is more compact and uses a flat stand. This frees up desk space compared to older Alienware designs and still allows for height, tilt, and swivel adjustments and VESA mount compatibility.
Regarding ports, this monitor features 2x HDMI 2.1, 1x DisplayPort 1.4, 1x USB 5Gbps Type-B upstream, 1x USB 5Gbps Type-A downstream, 1x USB-C 5Gbps downstream with 15W charging. The USB-C port is for data and charging, not video input and the lack of KVM switch could be a drawback for some.
If you decide to pick up this monitor, according to PCWorld, it does not include in-built speakers so you will need to connect your own. This is not a big issue because gamers looking for a premium playing experience will not want to rely on subpar in-built speakers anyway.
Is the AW3425DW the right fit for you?
Given its curved display, quality QD-LED display technology, and its fast response time, this monitor is a great pick for serious gamers looking for top-tier performance and immersion. Content creators who value color accuracy will also do well in picking up this Alienware monitor.
Alienware 34: $699.99 (Amazon US) / MSRP $799.99
This Amazon deal is US-specific and not available in other regions unless specified. If you don"t like it or want to look at more options, check out the Amazon US deals page here.
Surface Copilot+ PCs coming to classrooms from July 22, turbocharged with on-device AI
Amarok 3.3 Beta 2 replaces Phonon API with GStreamer
