If you are looking to add more deep bass to your Bose soundbar system, the Bass Module 700 and Bass Module 500 wireless subwoofer models are currently available at their lowest prices (purchase links down below).
For owners of compatible Bose soundbars, the Bass Module 700 is the matching low‑frequency unit designed to integrate wirelessly or via a wired connection. According to Bose, it is compatible with models including the Smart Soundbar 900, 700, 600, 300, the Bose TV Speaker, Soundbar 500, SoundTouch 300, and Lifestyle 600/650 systems.
Internally, they house a single high‑excursion driver paired with a "generously sized port." The design of these bass reflex subs resemble slot-loaded ports. Bose’s QuietPort technology is implemented in these which claims to minimize distortion at higher output levels as it deals with port chuffing and other port-related noises.
For those wondering how it can help, adding a dedicated subwoofer can shift low‑frequency reproduction away from the soundbar’s smaller drivers, potentially improving midrange clarity and extending the sub-60 Hz bass response that is crucial for enhancing the movie watching experience as well as for some genres of music.
Placement relative to walls and corners will influence performance, like for example when we place the sub against the corner of wall, we get a boost in the output sound pressure level (SPL) due to a phenomenon called corner loading. Bose’s guidance notes that the module should be positioned on the same floor as the soundbar for optimal results. Speaking of SPL, Bose does not publish or maximum SPL or frequency‑response figures for this.
Aside from the Bass Module 700, the Bose Bass Module 500 is also pretty good, except it is smaller and thus will likely not go as low as the 700 in the bass department.
Get the Bose Bass Modules at the links below:
Bose Bass Module 700 - Black- Wireless, Compact Subwoofer: $699.00 (Sold and Shipped by Amazon US)
Bose Bass Module 700 - White- Wireless, Compact Subwoofer: $699.00 (Sold and Shipped by Amazon US)
Bose Bass Module 500 Black: $399.00 (Sold and Shipped by Amazon US)
