If you are looking for a good gaming mouse that is also great for productivity, check out the Razer Pro Click V2, which is currently available at an all-time low price with a 20% discount on Amazon.
The Razer Pro Click V2 is the successor to the original model with a right-handed ergonomic design, which was co-developed with Humanscale. It promises improved wrist support and long-term comfort.
The Pro Click V2 uses Razer’s Focus Pro 30K optical sensor with support for up to 30,000 DPI for precise tracking on any surface.
The Razer Pro Click V2 has nine programmable buttons and a scroll wheel that supports notched and free-spin scrolling, along with left/right wheel clicks for horizontal navigation.
You can connect the mouse to your computer using Bluetooth and Razer’s 2.4GHz HyperSpeed Wireless via USB receiver (you can store the receiver inside the mouse). The internal battery is rechargeable via USB-C (the cable comes with the mouse) and rated to last up to 3.5 months under typical usage conditions. According to Razer, only five minutes of charging can get you two days of work.
The mouse is compatible with Razer Synapse 4 software, which allows users to customize shortcuts and macros, including AI-based productivity features like one-click access to text summarization or email drafting. It also lets you customize the mouse"s 14-zone RGB lights.
- Razer Pro Click V2 Wireless Gaming Mouse - $79.99 | 20% off on Amazon
