Video card Question on Ubuntu
I'm using Ubuntu 5.04 (hoary) and i installed the drivers the way i was told by going to the terminal and typing "sudo apt-get install xorg-driver-fglrx" and then i rebooted. but for some reason i still can't change my screen resolution i'd like it to be 1280x1064, but all i seem to be able to get is 1024x768, 800x600, 640x480, and 832x624. anyone help me out?
https://www.neowin.net/forum/topic/310720-video-card-question-on-ubuntu/
Here it is.. and that resolution isn't in there.. is there a way to put it in?
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands:
#  cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
#  sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum'
#  sudo dpkg-reconfigure xserver-xorg
Section "Files"
FontPath "unix/:7100"  # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
        # paths to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver  "keyboard"
Option  "CoreKeyboard"
Option  "XkbRules" "xorg"
Option  "XkbModel" "pc104"
Option  "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver  "mouse"
Option  "CorePointer"
Option  "Device"  "/dev/input/mice"
Option  "Protocol"  "ImPS/2"
Option  "Emulate3Buttons" "true"
Option  "ZAxisMapping"  "4 5"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. Radeon 9200 (RV280)"
Driver  "fglrx"
BusID  "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "DELL E770s"
Option  "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device  "ATI Technologies, Inc. Radeon 9200 (RV280)"
Monitor  "DELL E770s"
DefaultDepth 24
SubSection "Display"
  Depth  1
  Modes  "1024x768" "800x600" "720x400" "640x480"
EndSubSection
  Depth  4
EndSubSection
  Depth  8
EndSubSection
  Depth  15
EndSubSection
  Depth  16
EndSubSection
  Depth  24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen  "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Yes, it can be added in quite easily (and use "1280x1024"). You must be root (or use sudo to invoke your editor)
Since your "DefaultDepth" is listed as 24 bits, add the new resolution to the front of the list for that color depth. You can add it for all of them, too, if you wish.
Once edited, you may have to restart X (use CTRL+ALT+[backspace] to do this the easiest way)
    • Camtasia 2026.1.3 by Razvan Serea TechSmith Camtasia is the complete professional solution for high-quality screen recording, video editing and sharing. Camtasia 2026 makes editing your videos easier, and faster than ever. The new editor is packed with enhanced video processing, all-new production technology, an innovative library, and stock videos and other creative assets to help you create more polished, professional videos. No video experience needed. Anyone can create informative, engaging videos. Create professional, eye-catching videos: Add special video effects - Apply Behaviors that are perfectly designed to animate your text, images, or icons. Get a crisp, polished look without being a professional video editor. Drag-and-drop your edits - What you see is what you get. Every effect and element in your video can be dropped and edited directly in the preview window. And you can edit at resolutions up to beautiful 4K, for clear video at any size. Get exceptional performance - Camtasia takes full advantage of your computer’s processor with 64-bit performance. You’ll get fast rendering times and enhanced stability—even on your most complex projects. Camtasia 2026.1.3 changelog: Feature Updates Improved keyboard navigability in tool panels. Improved screen reader accessibility of headings in Preferences. Tool panels can now be resized using a keyboard-navigable control. Updated color of folder icon in User Library tab for better visibility. Grouped media now render a composite waveform considering all audio media within that group. Added Long Path Aware to the manifest of Editor and Recorder. Performance Improvements Improved performance for editing groups on the timeline. Improved the project loading performance when timeline has lots of trec media with cursor data. Updates for IT Administrators Updated cpp-httplib from 0.38.0 to 0.43.3. Updated expat from 2.7.4 to 2.8.0. Updated freetype from 2.13.3 to 2.14.3. Updated harfbuzz from 13.0.1 to 14.2.0. Updated libpng16 from 1.6.55 to 1.6.58. Updated pango from 1.57.0 to 1.57.1. Updated girepository from 2.86.3 to 2.88.0. Updated pcre2-posix from 10.47.0 to 12.0.2. Added new harfbuzz-gpu.dll. Updated FFmpeg from 7.1.1 to 7.1.2. Updated aom from 3.11.0 to 3.13.1. Updated dav1d from 1.5.0 to 1.5.1. Updated ogg from 1.3.5 to 1.3.6. Updated SDL2 from 2.32.4 to 2.32.10. Updated zlib from 1.3.1 to 1.3.2. Updated Nalpeiron binaries to version 4.4.69.3. Bug Fixes Fixed an issue which prevented some user submitted crash reports from being sent. Fixed a potential memory leak when decoding HEVC or VP9 video. Fixed a potential crash when trying to delete a range selection on a magnetic track. Fixed a bug with the Properties Panel showing stale properties when only a caption is selected on the timeline. Fixed an issue that could prevent the Opacity and Blur properties from being changed in the Background Removal effect. Fixed an issue where larger Camtasia online projects may fail to open in Camtasia Editor. Table of contents thumbnails are no longer created for Smart Player exports with no table of contents. Fix resetting skew revert to revert just skew and not scale as well. Fixed editing in Snagit with snagX file with Unicode characters. Fixed a bug where grouped visual media could be cropped in some cases. Fixed importing SnagX files with Unicode characters. Localization fixes. Download: Camtasia 2026.1.3 | 309.0 MB (Shareware) View: Camtasia Homepage | Tutorials | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • yeah it seems to be Edge only. The dialog buttons work as expected in Chrome and Firefox. The phone is using Android 16 (OneUI 8.5) and Edge version  149.0.4022.53
    • I'm not aware of this issue, but to help the other guys.  What version of Android are you using? Did you try a different browser? To see if Edge is the issue here.
    • I agree when are you going to read this (really poor BTW) article? Here is a better article so you actually know what is going on and answers questions you had in other comments --> https://arstechnica.com/gadgets/2026/05/speed-boosting-low-latency-profile-is-one-of-the-improvements-coming-to-windows-11/ It is unclear if one will be able to disable the new profile at this point but I am not seeing any reason why one would.
      Jamswaz earned a badge
      Marzoid went up a rank
    • Community Regular
      coch went up a rank
      Community Regular
      slackerzz earned a badge
