fedora 16 Flash Drive Installation: Operating System not found
Recently Browsing 0 members
Posts
By David Uzondu · Posted
Here's your first look at Raycast for Windows, now in beta by David Uzondu Last September, we reported that Raycast, the popular macOS command bar and launcher tool, was set to make its way to Windows in 2025. Since its launch in 2020, Raycast has quickly become the go-to app that people recommend for new Mac users due to its speed, UI, features, and plethora of extensions. People have been begging for a Windows build, and even a Linux one, for a long time. Now, the company has published a YouTube video showcasing the beta on a Microsoft Surface and explaining how you can get your hands on it today. It's all opened by pressing the default hotkey (Alt + Space). This gives you a central command bar to launch apps, run commands, and search for files. You get a lot of the core features right now, like a calculator that handles natural language queries, a full clipboard history manager, and tools for creating text snippets and quicklinks. For example, typing .pdf instantly filters for just PDF documents, and using a forward slash lets you navigate through folder paths directly. Once you find a file, pressing Ctrl + K opens a contextual action menu with options like "Show in File Explorer" or "Copy File." The included calculator is also a powerhouse, handling everything from basic math to natural language queries, like "time in Barcelona" or "days until August 12." The full clipboard history manager is a massive upgrade over the Windows default. It keeps a running log of everything you copy to your clipboard, including blocks of text, links, images, and files. You can open the clipboard history and search through every item you've copied. It also comes with a powerful filtering system. By pressing Ctrl + P, you can filter your history to show only text, images, links, or even just colors. Its Quick AI feature is also included and will be free for everyone during the beta period. That means you can ask it questions and get answers without needing a Pro subscription for now. Quick AI is built on a set of AI models, like GPT-4o mini, which maintains conversational context, allowing for natural follow-up questions, and you can browse your entire chat history. There's also an "AI search" feature, which is listed as coming soon. The most surprising part is the support for third-party extensions right out of the gate. Raycast built its reputation on an extensive library of integrations that connect it to services like Slack, YouTube, and GitHub. While some of these extensions are written for specific macOS features and are not compatible, many of the extensions are written in JavaScript, which means a huge number of them already work from day one on Windows. Image: @alvaniss1g on X As you can guess, the beta is not feature-complete. A lot of the heavy-hitting Pro features are still on the roadmap and are promised to be coming soon. This includes Cloud Sync to keep your settings consistent across machines, as well as the much-loved Raycast Notes feature. If you are a Pro user on Mac looking to switch, you may want to wait a little longer for full parity. Snippet expansion and calendar integration are also on the to-do list for future updates. Getting into the beta is a bit of a process. Access is being managed through a gradual rollout, with priority given to users who signed up for the waitlist announced last year. If you are on the list, you can expect to receive an email soon. And if you don't like the waitlist, your best bet is to find a friend who already has an invite code, as each invited user gets a few extra codes to share. Sorry, Linux users, but there is no word on your build at the moment, and we're not holding our breath. -
By Jdoe25 · Posted
We M$ and our 801 loved partner$ are having a data party ! -
By Copernic · Posted
Wise Disk Cleaner 11.2.4 by Razvan Serea Wise Disk Cleaner is a free disk utility designed to help you keep your disk clean by deleting any unnecessary files. Usually, these unnecessary, or junk files appear as a result of program's incomplete uninstalls, or Temporary Internet Files. It is best if these files are wiped out from time to time, since they may, at some point, use a considerable amount of space on your drives. Wise Disk Cleaner, with its intuitive and easy to use interface, helps you quickly wipe out all the junk files. Using the program is indeed easy. It also works fast when both scanning for files and deleting files. The new Wise Disk Cleaner has more advantages: improved performance, better interface and scans/cleans more thoroughly. Wise Disk Cleaner Free provides lifetime free update service and Unlimited Free technical support. The first Slimming System software Wise Disk Cleaner is the first system slimming tool, which will help you to remove Windows useless files that you don't need, such as Korean IME, Windows Sample music, videos, pictures, Installers and Uninstallers of Updates Patches etc. Wise Disk Cleaner 11.2.4 Build 844 changelog: Improved cleaning rules for WPS Office and Mozilla Firefox. Added cleaning support for Jetbrains Pycharm, Jetbrains WebStorm, Jitsi, Visual Studio Code, jv16 PowerTools, Kakao Talk, Kingo Root, Launchy, Layers of Fear, LBRY, League of Legends, Leapfrog Connect, and Leawo Prof Media. Fixed minor bugs from the previous version. Download: Wise Disk Cleaner 11.2.4 | 6.9 MB (Freeware) Download: Portable Wise Disk Cleaner 11.2.4 | 7.3 MB View: Wise Disk Cleaner Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware -
By Kavin25 · Posted
Hi everyone! I’m looking for some help. I’m using HelpWire for remote support, and while everything else works fine, I’m not getting any sound from the remote computer. Is there a setting I might be missing? Any tips would be appreciated. Thanks in advance!
Recent Achievements
Kavin25 earned a badge
Leonard grant earned a badge
pcdoctorsnet earned a badge
Phillip0web went up a rank
Rising Star
Epaminombas earned a badge
Popular Contributors
Tell a friend
