- 0
Cinema 4D Rigid Body Problem
Recently Browsing 0 members
Similar Content
Cinebench 2024 brings big upgrade with support for Windows on Arm, Apple M1/M2, and GPUs too
By hellowalkman,
- 3 replies
- 3 views
- 17 replies
- 5 views
Samsung is investigating an issue with pixels on the S22 Ultra
By Usama Jawad96,
- samsung
- samsung galaxy s22 ultra
- (and 9 more)
- 3 replies
- 4 views
- 1 answer
- 11,126 views
Microsoft's Outlook IMAP login issue is affecting several third-party email clients
By Usama Jawad96,
- 1 reply
- 12 views
CmptrPrgmr
I have Cinema 4D Release 13 and am pretty good at using it. What I am trying to achieve a hole bunch of little sphere that are 2cm in diameter fall into a bigger sphere and fill it up. I am using a cloner to make all the little spheres. I have a Rigid Body with Dynamics off and shape set to Static Mesh on the big sphere, and I have individual elements set to all on the cloner. When I play it. everything goes right but some of the little spheres will go right through the big sphere. I have tried so much to try to fix this but I can't seem to find anything.
Does anyone know a solution to my problem?
I solved my problem. What I did was I went into the project settings and went into the expert tab then changed the step per frame to 25 and that fixed it.
1 answer to this question
