Noticeable difference in speed between SATA2 (285MB/s) & SATA3 (550 MB/
I currently have an OCZ Vertex 2 SSD (read around 285MB/s; write 275MB/s)
Is an Intel 520 SSD (r: 550 MB/s; w: 500 MB/s) noticeable faster or doesn't it matter in day-to-day activities?
The SSD will be primary used for Windows booting, and starting of programs like Kaspersky IS, IE, OL2010, Photoshop Elements and a bit of Word and Excel etc.
Copying files would be faster, its the access speeds (seek time) you would notice the most between drives for normal opening of programs I would imagine, although I doubt it would be massively noticable between SSDs really
Keep tabs on the deals that occur and you can probably get a good deal on a recent SSD.
I bought a 120GB Vertex 3 for $100 after rebates a few months back.
I believe you can get a 128GB M4 for $120 currently. The OCZ drives seemed to have spiked in price lately.
Intel tends to be the most expensive of the bunch for whatever reason.
Depends what you do. If you spend a large amount of time copying files or if you play a lot of big games, you might notice the load and copy times increase from ssd to ssd.
General windows use? We're probably talking a fraction of a second increase.
Tray SATA6. You will notice a difference, PhotoShop will open off an SSD as fast a Painbrush.
@kiddingguy, for games, USB 3.0 has made life an inexpensive joy for me. I actually have some games that just don't like running off an SSD.
I have 2 OCZ Agility 3 SSD's in RAID 0, going at nearly 1.1GB/s read and write. I can boot into windows with a fully usable desktop after the bios screen in 12 seconds! I can open heavy programs such as Photoshop in 3 seconds! If you can afford it and the motherboard supports it, this is definitely the future!
Hmm..If it were me, I would say no.
I don't really care about boot times - my habit always was, and still is, turn on PC and make a drink. Boot time could be 3 minutes and I wouldn't notice.
Opening programs wise - office programs open instantly now, but they were only taking a second to open before.
I'm not going RAID and am not planning to use it as game-SSD.
Still worth it for booting into Windows and day-to-day usage like IE, Chrome, Outlook and other Office products?
Don't worry about SATA 2/3, just stick to your current SSD.
Or get a Vertex 4 if you have to satisfy your urge for an upgrade :)
@djdanster - eh, that's slow for an SSD.
i5-2400 and a Corsair Force 3 SSD here and Win 7 starts in 5 seconds (from BIOS to usable desktop) and Photoshop launches in 1 second or less.
Haha, yea alright then 5 seconds.... I can't believe that :huh:. Video?
Don't have a smartphone but otherwise I would. Timed it again to double check and it came in at 7 seconds.
Does your BIOS have instant on or something similar?
Do you have an UEFI BIOS? Or are you starting the clock after the POST has finished?
it should prolly only take about 12 seconds on an SSD cus windows wont be shifting 250MB' sec or 1GB a sec, its the seek time on SSD's that do it. windows loads lots of small files so the faster it finds em the faster you boot thats why its so much faster than mechanical drives. Dunno about photoshop but i think you could wait an extra few seconds, its not that big of a deal. The SSD will always be limited by the slowest drive you wont copy/write stuff to.
    • This Dell 27 inch 4K 120Hz IPS monitor is really cheap after a very long time by Sayan Sen Recently we covered a really good deal on an AMD RX 9070 three-fan model that's available at slightly above its MSRP. If you are looking for a GPU for 1440p gaming that's around the performance of the Nvidia RTX 5070 you should most definitely check it out. Let's say that you are looking for a monitor to pair that up with too. The Samsung 49" G9 curved QD-OLED superultrawide is a good option that can provide an immersive experience. However despite being a very good deal currently (at $855), it may seem unaffordable to you, or you may simply not want to spend as much on a monitor. In that case Dell's S2725QS can be a very good option as it's on sale at the moment for its lowest price in over six months (purchase link under the specs table down below). The big highlight of the Dell S2725QS is its 27-inch IPS panel with a 3840 x 2160 (4K UHD) resolution, offering a high pixel density that can make text appear sharper while also providing plenty of screen space for productivity and media consumption. The display supports a refresh rate of up to 120Hz through both HDMI and DisplayPort, making it suitable not only for everyday desktop use but also for smoother gaming and scrolling. AMD FreeSync Premium support is included as well, helping reduce screen tearing during gaming sessions. The screen has fairly good brightness and color accuracy so you can use it for general work purpose, though photo/video editing is probably not going to be the best match for this. The technical specs of the Dell S2725QS are given in the table below: Specification Value Viewable Screen Size 27 in (68.58 cm) Screen Mode 4K UHD Maximum Resolution 3840 × 2160 Maximum Preset Resolution 3840 × 2160 @ 120 Hz Standard Refresh Rate 120 Hz Panel Technology In-plane Switching (IPS) Backlight Technology LED Edgelight System Pixel Density 163 PPI Response Time 8 ms GTG, 5 ms GTG, 4 ms GTG Horizontal Viewing Angle 178° Vertical Viewing Angle 178° Brightness 350 cd/m² (nits) Native Contrast Ratio 1500:1 Color Support 1.07 Billion Colors Color Gamut 99% sRGB (CIE 1931) Adaptive Sync AMD FreeSync Premium HDCP Support Yes Mount Type Panel Mount VESA Mount 100 × 100 mm Maximum Height Adjustment 13 cm Tilt -5° to 21° Swivel -30° to 30° Pivot ±90° Stand Adjustments Tilt, Swivel, Height, Pivot Glass Hardness 3H Horizontal Frequency 27–270 kHz (DisplayPort 1.4 / HDMI 2.1) Vertical Frequency 48–120 Hz (DisplayPort 1.4 / HDMI 2.1) Video Inputs 2 × HDMI 2.1 (HDCP 1.4 & 2.3), 1 × DisplayPort 1.4 (HDCP 1.4 & 2.3) Operating Temperature 0°C to 40°C Storage Temperature -20°C to 60°C Operating Humidity 10%–80% (Non-condensing) Storage Humidity 5%–95% (Non-condensing) Get it at the link below: Dell S2725QS 27-inch 4K 120Hz IPS monitor: $218.49 (Sold and Shipped by Amazon US) (Was: $280) Good to know This Amazon deal is U.S. specific, and not available in other regions unless specified. We only use first-party seller links (at the time of article publishing); ensure that you purchase from a first-party seller link only. Check out Today's Deals on Amazon | or our recent tech deals. Become a Prime member (for Students or SNAP) via Neowin Get Prime Access - Prime for half price (for qualifying Medicaid, EBT, SNAP) Subscribe to Prime Video, Audible Plus, Music Unlimited or Kindle Unlimited via Neowin As an Amazon Associate, we earn from qualifying purchases
    • Looks almost like what our office provides us, excluding the leg rest for obvious reasons 😴
    • Forget the iPhone. What about Android? Most Samsung Galaxy phones sold in the USA are manufactured in Vietnam. Asian countries have the infrastructure that the USA doesn't have. This is why most electronics are not made in the USA
    • The RAM would still probably be more expensive than what they were paying last year.
      jessse3334 earned a badge
      Excellence2025 earned a badge
      flexorcist earned a badge
      macoman
      64
