Running Windows 7 64-bit Ultimate on Mainboard : Acer FRS780M, Chipset : AMD 780
I have a very old Sound Blaster Audigy that has always worked for me despite its age, I recall being able to select quadraphonic sound back in my old 32-bit Win 7 just fine. Now I am trying to use 4 speakers again, but when I select "quadraphonic" using the windows playback properties dialog, and then test the rear speakers, the demo audio chime switches back and forth between the front and rear speakers, like it can't decide where to output it to (the speakers are connected to the audigy using two 3.5mm stereo jacks; one for the front in the green plug and one for the rear in the black plug). I also tried switching to "4/4.1 Speakers" using the Creative Audio Console, and about 3 seconds after selecting it, it quickly switches my selection back to "2/2.1 Speakers". What the hell?
So I decide to try my motherboard's onboard sound card. Now I don't have the official drivers for it, Windows just installed it as a "High Definition Audio Device" I installed the official drivers for it, it is called "Realtek High Definition Audio". It has six 3.5mm jacks, one green for front and one black for rear, so I plug my speakers in and set it to the default device. Upon testing the quadraphonic setup in the Win7 dialog, I can hear the front two speakers just fine, but nothing comes out of the rear speakers. I am certain I have the right jack, because windows tells me so in the properties dialog. I also checked the balance levels, and the volume for every speaker is turned up max.
Any ideas why I can't seem to use 4 speakers any more? I have tried rebooting with the speakers plugged in, I'm not running any background programs that could affect the audio.
Whoops, apparently my Realtek onboard required the use of the grey "side speaker" plug, and not the one that would actually make sense for a 4 speaker setup; "rear speakers". Still no idea why the Audigy won't work anymore, but most likely the fact that for years, it has been sitting about 5mm away from my 5770 video card that reaches 85*C on a hot day.
    • Ridiculous claim that the labor cost difference of $6000 annually would increase cost per phone by $200. The employees produce 3 phones per month or what?
    • Sparkle 2.20.1 by Razvan Serea Sparkle is a free, open-source Windows optimization tool designed to make your PC faster, cleaner, and more private. With Sparkle, you can easily debloat Windows by removing unnecessary apps and services, disable Microsoft tracking to enhance privacy, and apply performance tweaks to boost speed. Its cleaner removes junk and temporary files, while every change is safe and fully reversible. Sparkle also features a modern, user-friendly interface with automatic updates, making system maintenance simple. Explore over 39 tweaks, from disabling telemetry and hibernation to optimizing network and game settings, all aimed at customizing and enhancing your Windows experience. Sparkle supports Windows 10 and 11. Sparkle 2.20.1 changelog: You can now change the Animation Direction from Up, Left, or Off. Added configurable animation direction (Up, Left, Off) for improved accessibility Added TTL caching to the system info backend Refactored tweak application flow to await NvidiaProfileInspector Improved IPC listener cleanup to correctly remove specific listeners Fixed online status not updating after successful network requests Updated system info tests to support backend caching Removed electron-toolkit utils dependency in favor of internal is.dev helper Fixed unwanted files and folders being included in application bundles Download: Sparkle 2.20.1 | Portable | ~100.0 MB (Open Source) Links: Sparkle Website | Github | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Never used the G7 Pro, but I've never had a good experience with that style of d-pad and fighting games.
    • And I just bought a seat cushion for my mesh chair. The chair feels nice but the first time I sat in it with boxers, I realized I don't like the feel of mesh on my legs. 😂
    • "This Dell 27 inch 4K 120Hz IPS monitor is really cheap after a very long time" ... Lol.
      Asgardi earned a badge
      jessse3334 earned a badge
      Excellence2025 earned a badge
      macoman
      64
