Fan Speed not changing on load
Ok so I was having some framerate problems with some games couldent figure it out. seems to be better*
Other night I Decided to clean my computer out without the use of compressed air and cleaned everything with a paper towel and alot of Qtips (dry).
I unscrewed the the 2 fans my computer has and cleaned them pretty good and heatsinks all the ram and grafix card. I also Qtipped all connectors and all around the motherboard and capaciters. (stayed grounded to chassis during everything)
Why fan speed not Increase with load. Like backing up games on steam Was all power to backing up and now no change at all in fan speed or anything. Did I miss somthing when I was Doing this I know I got case fan backwards and flipped it back around and thats it.
Second random Question I have This computer was a store baught one from a few years back the manufacurers website says
Does that mean the limit of what the hardware will support or the OS it came with support originally had 32bit vista
Memory Support Four DDR2 800/667/533/400 MHz SDRAM slots
Support up to 4 GB system memory
https://www.neowin.net/forum/topic/1102965-fan-speed-not-changing-on-load/
Depends really, doesnt vista only see 4gb under 32bit? Not sure on the hardware capabilities as you havent mentioned what computer you have etc.
Has the fan ever gone on full under load? If it hasnt there might be an option in the bios to set the limit of it, not sure though.
It has on plenty of occasions before I cleaned it out Mostly when backing up files on steam or
http://support.gateway.com/s/PC/R/1015322R/1015322Rnv.shtml is my computer as well just upgraded psu to a 410watt to support an upgraded grafix card of an nvidia 450gts
Using core temp to watch it and it hovers around 40C
Will post test with load tester
You honestly can't expect us to help you with what you have just posted, right? Please provide at least some sort of detail - for starters, your system specs.. Second, are the fans hooked up to the motherboard, or the power supply (PSU)? Also, do they support PWM?
If they're hooked up to the motherboard, and support PWM, try using a program like SpeedFan. If they're hooked up to the PSU, they'll run at 100%.
Ok I got it load tested cpu fan responded although temp got to 62C before I Stopped the test lots of stuttering as well
Case fan did not swapped it and it worked must have killed the Original one.
Speed fan didnt affect the speed of any fans in my computer unfortuantly
Excuse my ignorance I dont know some of the common sense things with computers but I try
specs
Operating System
MS Windows 7 Ultimate 64-bit SP1
CPU
AMD Phenom X4 9500
Agena 65nm Technology
RAM
3.00 GB Dual-Channel DDR2 @ 334MHz (5-5-5-15)
Motherboard
ECS MCP61PM-GM (Socket AM2 )
Graphics
Acer S201HL (1600x900@60Hz)
1023MB GeForce GTS 450 (EVGA)
Hard Drives
298GB Seagate ST3320620A ATA Device (PATA)
466GB Western Digital WDC WD50 00AAKS-22YGA SCSI Disk Device (ATA)
Optical Drives
No optical disk drives detected
Audio
Realtek High Definition Audio
    • BS, I've yet to run into a typical pc user that uses it at all, let alone half the population.
    • Codec Tweak Tool 6.7.7 by Razvan Serea This tool is a Swiss army knife for managing codecs and codec settings. Codec Tweak Tool will scan for broken filters and remove them. If the tool detects something that is broken, it will then prompt you with the details and you will be given the option to remove the broken item. Generate a detailed log of all installed codecs and filters, enable/disable more than 250 popular codecs and filters (if they are installed), manage preferred source filters, and reset settings. With this tool you can do things like: Scan the registry to detect and remove broken references to codecs and filters. Enable/disable more than 200 popular codecs and filters (if they are installed). Manage preferred source filters (a.k.a. splitters). Detect broken codecs and DirectShow filters. Fix problems with the standard DirectShow filters of Windows. A fix for a specific sound problem. Generate a text file with detailed information about all installed codecs and DirectShow filters, along with other relevant system information. Reset settings to recommended values for many popular codecs and DirectShow filters. Configure audio output settings for several popular audio decoders. Several configuration options for a few DirectShow filters that don't have an easily accessible interface for those options. Easy access to the configuration interfaces of various codecs and DirectShow filters Backup the settings of several codecs and DirectShow filters. Replace your current settings with those from a previous backup. Manage DirectShow filters - Enable or disable DirectShow filters. Manage ACM/VFW codecs - Enable or disable ACM/VFW codecs. Enable or disable DirectX Media Objects. Configure your preferred DirectShow source filters (a.k.a. splitters) for several common file extensions. Enable or disable the generation of thumbnails for several common video file formats in Windows Explorer. Download: Codec Tweak Tool 6.7.7 | 1.5 MB (Freeware) View: Codec Tweak Tool Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • The site is pretty sparse on features / tech specs. Can I plug it into a PC/hone/Switch via USB-C and use it as an external display? If so, what's the virtual resolution of the screen, the refresh rate, PPI of the image etc? Is the text crisp enough to use for coding at say 12pt? Is it good enough for playing dark games, like say Path of Exile 2? How about fast games like car racing games? Just how do they expect anyone to order this thing without giving out all this info?
      Vincian earned a badge
      Jocimo earned a badge
      Windows Guy earned a badge
      Prasann earned a badge
