Probably should look for a real forum about LEDs, but maybe someone on here could help
I am building a Light Fixture, that I hope to have a production run on in the future.
I am using a 5 meter LED strip, cut into separate strips. I want to dim these, however the only info I can find to do this is to use a PWM inline dimmer. This one goes between the power supply and the leds. This is not what I want though. I want to build the dimmer into the lamp, and the PWM switches are too big. I have room for a dial potentiometer though. Does anyone know if those can be used to dim LED strips? How do I find out what potentiometer to look for as far as range goes.
https://www.neowin.net/forum/topic/1109431-led-dimming-help/
I am using led strips already. Its a 5 meter segment cut into 8 strips. Total power consumption will be around 24 watts 2 amps. I am having a hard time finding a pot that is 12v and can handle that kind of wattage. Any suggestions on where to look for one? I have considered a controller, would that be a better route
Secondly as a fall back, I have looked at just using a regular push button switch or even a rotary switch that would turn on various strips and different clicks. I can't seem to find a 12 volt switch that would handle 24 watts, most are just .5 to 1 watt. Would it be possible to use a 125 volt switch on a 12 volt system
You don't need a 12V pot, you just need any pot thats got a voltage > 12V. Then depending on what brightness reduction you want you select the resitance of it, e.g. a 10 Ohm pot. won't dim it very much but a 1M Ohm will probably have the LEDs completely off without turning the pot much.
I went to that potentiometers.com site and found one that I would prefer to use, and originally was looking for something like this
http://www.potentiometers.com/LT.cfm
Looking at the electrical specs on it, I can't tell if it will work with my led strips described above
  • 4 weeks later...
  • 1 month later...
Generally speaking, the higher the SMD number, the brighter the light. Also the higher the amp draw.
3528 strip are overly bright for interior lighting......which means 5050 strip would be blinding.
Exterior lighting should be at least 5050s, if not 5630s.
If you plan on using a dimmer, keep this in mind: You need a switching dimmer, not your standard voltage dimmer. LEDs are on/off, with no in-between. That means lowering the voltage ain't gonna do squat. You need to reduce the amount of time the LEDs are lit -- basically, you need to adjust how rapidly they are switched on and off. A switching dimmer will decrease the amount of on/off cycles, increasing the amount of off time between on cycles -- but so fast that human eyes don't detect any flicker, only dimmer light.
    • BleachBit 6.0.1 Beta by Razvan Serea When your computer is getting full, BleachBit quickly frees disk space. When your information is only your business, BleachBit guards your privacy. With BleachBit you can free cache, delete cookies, clear Internet history, shred temporary files, delete logs, and discard junk you didn't know was there. Designed for Linux and Windows systems, it wipes clean thousands of applications including Firefox, Microsoft Edge, Google Chrome, Opera, Safari, and more. Beyond simply deleting files, BleachBit includes advanced features such as shredding files to prevent recovery, wiping free disk space to hide traces of files deleted by other applications, and vacuuming Firefox to make it faster. Better than free, BleachBit is open source. BleachBit has many useful features: Delete your private files so completely that "even God can't read them" according to South Carolina Representative Trey Gowdy. Simple operation: read the descriptions, check the boxes you want, click preview, and click delete. Multi-platform: Linux and Windows Free of charge and no money trail Free to share, learn, and modify (open source) No adware, spyware, malware, browser toolbars, or "value-added software" Translated to 64 languages besides American English Shred files to hide their contents and prevent data recovery Shred any file (such as a spreadsheet on your desktop) Overwrite free disk space to hide previously deleted files Portable app for Windows: run without installation Command line interface for scripting and automation CleanerML allows anyone to write a new cleaner using XML Automatically import and update winapp2.ini cleaner files (a separate download) giving Windows users access to 2500+ additional cleaners Frequent software updates with new features Going beyond standard deletion of files, BleachBit has several advanced cleaners: Clear the memory and swap on Linux Delete broken shortcuts on Linux Delete the Firefox URL history without deleting the whole file—with optional shredding Delete Linux localizations: delete languages you don't use. More powerful than localepurge and available on more Linux distributions. Clean APT for Debian, Ubuntu, Kubuntu, Xubuntu, and Linux Mint Find widely-scattered junk such as Thumbs.db and .DS_Store files. Execute yum clean for CentOS, Fedora, and Red Hat to remove cached package data Delete Windows registry keys—often where MRU (most recently used) lists are stored Delete the OpenOffice.org recent documents list without deleting the whole Common.xcu file Overwrite free disk space to hide previously files Vacuum Firefox, Google Chrome, Liferea, Thunderbird, and Yum databases: shrink files without removing data to save space and improve speed Surgically remove private information from .ini and JSON configuration files and SQLite3 databases without deleting the whole file Overwrite data in SQLite3 before deleting it to prevent recovery (optional) BleachBit 6.0.1 Beta release notes: BleachBit 6.0.1 beta is now available for testing. This maintenance-focused release includes bug fixes, updated translations, and a range of safe enhancements. This release fixes a Windows security issue that could allow arbitrary file deletion during privileged cleaning (reported by Zeze with TeamT5). It also adds new cleaners (including a DNS cache cleaner, Claude Code, and Visual Studio Code forks), support for multiple Chrome and Edge profiles, new deep scan options for developer directories like node_modules and venv, and safer, faster file shredding. All Platforms Added cleaners for Claude Code, DNS cache, and many Visual Studio Code forks. Added support for multiple Chrome and Edge profiles. Chrome can now clean downloaded AI models. Deep Scan can optionally remove venv, __pycache__, node_modules, and .angular directories. Deep Scan is faster by skipping directories on the keep list. File shredding is safer, faster, and leaves fewer recoverable traces. Improved handling of cookies, symlinks, Unicode filenames, external processes, and configuration files. Improved Expert Mode warnings and long warning dialogs. Fixed crashes related to cleaner detection, invalid Unicode, and malformed cleaner data. Clipboard is now cleared automatically after shredding files via paste operations. Linux Added AppImage support. Added cleaners for Visual Studio Code, Codeium, Librewolf (.deb), Transmission (Flatpak), and Profanity. Improved Linux trash detection, including Snap-installed applications and mounted drives. Fixed Wayland root CLI issues and several Snap-related problems. Improved package dependencies, AppStream metadata, and desktop file handling. Fixed startup crashes when Python Requests is unavailable. Windows Fixed a security vulnerability that could allow arbitrary file deletion when cleaning with elevated privileges. Added %WindowsSystem% variable support. Improved clipboard clearing using native Windows APIs. Improved installer experience on unsupported Windows versions. Reduced installer size and improved application robustness. Fixed Unicode handling, filename anonymization, Git revision reporting, and splash screen stability. [full release notes] Download: BleachBit 6.0 | Portable | ~20.0 MB (Open Source) View: BleachBit Home page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • DriversCloud 12.1.6 by Razvan Serea With DriversCloud (formerly My-Config.com), you can explore your computer easily, safely and free. The application quickly scans your PC and identifies the hardware and software components. DriversCloud then establishes a list of the different drivers compatible with your OS and hardware. Download the drivers needed for the proper functioning of your computer. To detect your drivers, DriversCloud also displays a detailed summary of your hardware and software configuration, analyzes your BSOD, monitors in real-time your PC voltages and temperatures and lets you share your configuration online. Once the hardware components have been detected, you will be able to obtain with just a few clicks the latest drivers corresponding to the identified hardware. You can record your configuration on the site for free, and can get the corresponding URL to post the configuration to technical forums, e-mail and social networks. You can also download the detection result (the configuration) as a PDF file. To protect the user's privacy and data confidentiality, a 4-level confidentiality system was created that filters the XML marks and gives control to the user. The default level can be modified in the preferences. Using the maximum level will prevent the user from publishing his configuration and generating a corresponding PDF file. In non-connected mode, each XML configuration is stored on the server for one day (for practical reasons). However, you are given the opportunity to manually delete it. Created in 2004, and continually improved, My-Config.com has established itself on the web as a free service to PC users running Windows and Linux operating systems. The service is designed to work with the most common Internet browsers (Edge, Firefox, Chrome, Safari). Download: DriversCloud 64-bit | 20.0 MB (Freeware) Download: DriversCloud 32-bit | 18.9 MB Link: DriversCloud Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      AndreaB earned a badge
      agatameier earned a badge
      ssd21345 earned a badge
    • Contributor
      MarkHughes4096 went up a rank
      Contributor
