Shell Script Help on file reading
Hi,
I need a little help on file reading. I have a file and its contents are like
123456789123456789123456789
987654321987654321987654321
231297301283120381290382133
Now I need script to format this file like
A B C D E F G H I J K L M
123 456 789 123 456 789 12 3 4 56 7 8 9
987 654 321 987 654 321 98 7 6 54 3 2 1
231 297 301 283 120 381 29 0 3 82 1 3 3
i.e the first line shows the differentiating columns and the rest of the lines following those columns.
Please help me on how this can be done.
Thank you.
https://www.neowin.net/forum/topic/1136228-shell-script-help-on-file-reading/
Is the break down the same,
3-digits 3-digits 3-digits 3-digits 3-digits 3-digits 2-digits 1-digit 1-digit 2-digits 1-digit 1-digit?
This might be an awkward way about the problem but,
#! /bin/bash
for i in `cat filename.ext`;
do
echo ${i:0:2} ${i:3:6} ${i:7:9} ${i:10:12} ${i:13:15} ${i:16:18} ${i:19:20} ${i:21:21} ${i:22:22} ${i:23:24} ${i:25:25} ${i:26:26} >> outputfiles.ext
done;
Clearly not the cleanest way of doing it - P.s. I have not tested this as I am on an android phone lol
You are very close. This is exactly what I want. In simple terms, I want to break the characters and present them in a format like first three characters. then 4-6. then 7-12, then 8-9 and so on. The length of each line in the file remains the same and so I need to format it in different ways.
I tested your code, but the output is not coming according to the code. It would have been perfect otherwise.
Thank you :)
Do you mean,
1: The wrong number of digits broke down? (Which is possible as I wrote that on an Andriod phone and I cannot see the whole block of code.)
2: The IFS the internal field separate is not triggering the line breaks? (Which is possible depending on where and what is used to create the file in the first place)
This is coming as output of your code
12 456789 891234567 23456789 56789 89
98 654321 219876543 87654321 54321 21
12 121112 123123124 12312412 12412 12
This is not consistent with the code. Your code has divided each line into 12 parts. Therefore the output should have been in 12 parts. The file has been created just by typing the lines to check how it can be broken up.
I would be interested in knowing what this is for LOL
I did the example from memory and I made a mistake in thinking is Variable:Start Reference:End Reference where in actuality it is Variable:Start Reference:Length
# YOUR EXAMPLE
[Tim.IT-8] ? cat example.txt
# SCRIPT
[Tim.IT-8] ? cat example.sh
#! /bin/bash
# VARIABLES
INPUTFILE=example.txt
OUTPUTFILE=example_completed.txt
# CLEAR THE SCREEN
clear
# PROCESS
for i in `cat $INPUTFILE`;
do
echo "${i:0:3} ${i:3:3} ${i:6:3} ${i:9:3} ${i:12:3} ${i:15:3} ${i:18:2} ${i:20:1} ${i:21:1} ${i:22:2} ${i:24:1} ${i:25:1} ${i:26:1}" >> $OUTPUTFILE;
done;
# CLEANUP
unset INPUTFILE;
unset OUTPUTFILE;
# RESULTS
[Tim.IT-8] ? cat example_completed.txt
# YOUR EXPECTATION
  • 2 months later...
Hi tim, sorry for the delayed response.
I checked your code and thanx a ton for this. It is now coming as expected. I also understood the code this time. I have a file where the lines are like
xyz12345	 12345    mprls   12345
Here the blank spaces are also character and every bit of it represents a format. e.g 1st 3 letters will represent something, 4 something else, 5-6, 7-9 and so on. It is for my own clarity, otherwise I have to debug the code manually where the debug file consists of thousands of such lines of equal width and the same format.
Thanx a lot for this. I will check this again on the raw file and if it can format the blank spaces as well.
    • It's the only reason I finally have an iPhone (for work) and enjoy using it so much that I'm tempted to move from android next time I need to replace my own device
    • So is Russia, China, Iran, North Korea, just to mention a few. What's your point? Everyone is a threat from their enemies' perspective. I'd say that Israel is only a threat to their immediate enemies like Hamas, Hezbollah and the Iranian regime, not to anyone else.
    • The government is not the good guy either. You propose 99% of people require that the government overreach and govern their freedom of information and privacy, while ignoring the government is made up 100% of people, of which 99% are (as you described) brain dead. You can't have both. The reality is Signal is absolutely right and the government is doing what it has always done. Ignoring that we are their boss and grabbing all the power they possibly can to make sure we aren't. Your (societies) ###### parenting is not reason enough as to why I can't have a safe platform for my data/information. Thinking the government is helping is precisely what they are targeting psychologically to take suckers like you for a ride. "Think of the children" was, has, is, and will always be a mechanism of control. In the rare occasion it's actually essential the mass consensus has always been there and it doesn't become a debate.
    • Google Chrome 149.0.7827.103 (offline installer) by Razvan Serea The web browser is arguably the most important piece of software on your computer. You spend much of your time online inside a browser: when you search, chat, email, shop, bank, read the news, and watch videos online, you often do all this using a browser. Google Chrome is a browser that combines a minimal design with sophisticated technology to make the web faster, safer, and easier. Use one box for everything--type in the address bar and get suggestions for both search and Web pages. Thumbnails of your top sites let you access your favorite pages instantly with lightning speed from any new tab. Desktop shortcuts allow you to launch your favorite Web apps straight from your desktop. Chrome has many useful features built in, including automatic full-page translation and access to thousands of apps, extensions, and themes from the Chrome Web Store. Google Chrome is one of the best solutions for Internet browsing giving you high level of security, speed and great features. Important to know! The offline installer links do not include the automatic update feature. Download web installer: Google Chrome Web 32-bit | Google Chrome 64-bit | Freeware Download: Google Chrome Offline Installer 64-bit | Direct Link | 131.0 MB Download: Google Chrome Offline Installer 32-bit | Direct Link | 119.0 MB Download page: Google Chrome Portable Download: Chrome ARM64 | Direct Link View: Chrome Website | Release Notes Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Very Popular
      Captain_Eric earned a badge
      Very Popular
      amusc earned a badge
      DJC50PLUS earned a badge
    • Proficient
      Eric Biran went up a rank
      Proficient
