If you have a 12-inch Surface Pro, Microsoft has a firmware update for you. The January 2026 firmware update for the cheapest Surface Pro is now available with security improvements, better connection with the Surface Pen, and simplified device management for IT admins.
Here is what is new in the update:
- Security:
- Strengthen your device’s security. We’ve addressed potential security vulnerabilities that may lead to unexpected shutdowns and privilege escalation.
- Reliability:
- Write, erase, and navigate smoothly with your pen. We’ve fixed issues where the Surface Slim Pen 2 unexpectedly loses pairing after inking, pen erasing isn’t stable, and the cursor position isn’t aligned to the pen during hovering.
- Performance and usability:
- Simplify device management. System administrators now have the option to turn off the stop error triggered by a long power-button hold. They can set the value for PowerButtonBugcheck to 0 in the registry.
| Windows Update Name | Windows Device Manager |
| 3.0.8.0 | Surface Panel Driver v2 - Monitors |
| 3.8.3.22 | Surface Touch - Firmware |
| 1.0.4458.2600 | Qualcomm(R) System Manager GPIO Device - System devices |
| 1.0.4458.2600 | Qualcomm Power Engine Plug-in Device - System devices |
| 6.215.59.0 | Surface Integration Service - System devices |
| 1.0.4458.2600 | Qualcomm(R) EVA Device - System devices |
| 0.0.440.0 | Surface Integration - System devices |
| 4.8.3.22 | Surface Touch - Firmware |
| Supported Configurations | 12-inch Surface Pro |
| Supported Windows Versions | Windows 11 version 24H2 and newer |
| How to get the update | Windows Update Surface Support website (manual installation) |
| Update Size | 486 MB (manual installation only) |
| Additional Steps | The update does not contain any known bugs or issues |
The 12-inch Surface Pro has a six-year lifecycle, and it will remain supported until May 20, 2031. If you are looking for a small, affordable Windows tablet, you can grab the 12-inch Surface Pro for $799 on Amazon.
