MIT's stunning 'bubble wrap' device squeezes water out from thin air even in deserts
Image by Matteo Roman via Pexels
Massachusetts Institute of Technology (MIT) engineers have built a new kind of device that can pull clean drinking water straight out of the air—no electricity needed. It’s designed for areas where water is scarce and traditional sources like rivers or lakes aren’t reliable. Right now, more than 2.2 billion people globally don’t have access to safe drinking water. In the United States alone, 46 million face water insecurity, with either no running water or water that’s not safe to drink.
This new device, called an Atmospheric Water Harvesting Window (AWHW), uses a unique hydrogel panel that looks like black bubble wrap. These dome-shaped bubbles soak up water vapor from the air, especially at night when humidity is higher. During the day, sunlight makes the vapor inside evaporate. That vapor then condenses on a glass surface and drips down through a tube, turning into drinkable water.
The AWHW doesn’t rely on power sources like batteries or solar panels. It’s completely passive, meaning it works on its own. The team tested a meter-sized panel in Death Valley, California, one of the driest places in North America, and got between 57.0 and 161.5 milliliters of water per day even with humidity as low as 21 percent. That’s more than what other similar passive devices have managed.
“We have built a meter-scale device that we hope to deploy in resource-limited regions, where even a solar cell is not very accessible,” said Xuanhe Zhao, a professor at MIT. “It’s a test of feasibility in scaling up this water harvesting technology. Now people can build it even larger, or make it into parallel panels, to supply drinking water to people and achieve real impact.”
Another cool part of the design is how they kept the water safe to drink. Usually, these kinds of hydrogels use salts like lithium chloride to absorb more vapor but that can lead to salt leaking into the water, which isn’t ideal. To solve this, MIT’s team mixed in glycerol, a compound that helps keep salt locked inside the gel. In testing, the lithium ion concentration in the harvested water stayed below 0.06 ppm (parts per million), which is way below the safe limit.
The hydrogel domes also give the material more surface area, letting it collect more vapor. The outer glass panel is coated with a special polymer film that helps cool the glass, making it easier for vapor to condense.
“This is just a proof-of-concept design, and there are a lot of things we can optimize,” said lead author Chang Liu, now a professor at the National University of Singapore. “For instance, we could have a multipanel design. And we’re working on a next generation of the material to further improve its intrinsic properties.”
Published in Nature Water, the study says the AWHW could last at least a year and shows promise for making safe, sustainable water in places with harsh climates. The researchers believe an array of vertical panels could one day supply water to individual households, especially in remote or off-grid locations.
Source: MIT News, Nature
This article was generated with some help from AI and reviewed by an editor. Under Section 107 of the Copyright Act 1976, this material is used for the purpose of news reporting. Fair use is a use permitted by copyright statute that might otherwise be infringing.
Microsoft Weekly: Windows 10 end of support toolkits, new builds, and more
Astonishing new tech could kill headphones forever as it bends sound right into ears
