I've seen many people here ask what a distro is or what KDE is many times. Hopefully this topic will clear those questions up. The words are categorized.
Beginner Linux Vocabulary
Distro - Short for Distribution, a distro is a set of programs combined with the linux kernel to create an operating system.
Kernel - The core of Linux. The kernel is what controls the hardware and is what every linux distro is built upon. The latest kernel to the date of this writing is 2.6.36. Using the term Linux refers to the kernel, not an operating system as Linux is not an operating system but the kernel per se. Linux is typically misused in this manner.
Bash - Bourne Again Shell is a command line terminal in Linux. For alot of distros (esp older ones) the shell is the only way to install programs and configure the system. If a Linux Distro didnt come installed with a GUI, it will typically boot into this. For a guide on using the shell view this free e-book: http://tille.garrels.be/training/bash/
Root - The ruler of all Linux systems. This is a user that you have access to that can do anything to a linux system. It is highly recommended that you don't use root as it can damage a system if used incorrectly.
Linus Torvalds - The one who wrote the linux kernel in 1991.
Sudo - Stands for Super User DO, allows a user to have root access without logging in as root. Typically used from the command line.
Software Vocabulary
Compile - Installing an application from it's source code. Another name for this word is build.
Source - The actual code that a program is coded in.
Binary - Usually a program or package that is encoded in binary(the 0's and the 1's), another term for this is machine language.
Package - A piece of Software like gtfp.
Dependency - A package that a package depends upon to work.
Package Manager Vocabulary
apt - Debian linux's packaging system. Apt uses .deb files. Apt is most popular for it's extension, apt-get(see below).
apt-get - An extension of Debian's apt package manager. Apt-get employs the search and get method found in todays package managers.
Portage - Gentoo Linux's packaging system. Portage is more powerful for it's ability to customize it in so many ways for almost any need. Alot of users pick Gentoo just for Portage. Portage compiles programs by source.
YaST - Yet Another Setup Tool is SuSE's front end to it's package manager. YaST is also used to manage the settings and aspects of the system.
RPM - Redhat Package Manager is among the widely used package manager. Originally created by Redhat, it's now used by a handful of Linux Distributions including but not limited to Fedora, Mandriva, SUSE and more.
Pacman - Arch Linux's Package Manager. Allows a user to install apps with 1 command from the terminal. Name has no meaning
Ports - A BSD package manager for which was Portage(see above) is based off of. Installs software from source.
Yum - Yellow dog Updater, Modified. Yum is a package management utility used by several distributions including Fedora for RPM and centOS.
Graphical User Interface Vocabulary
Desktop Environment - DE for short, are numerous applications bundled together in a package to provide the user with a nice working environment to use the computer. Typically comes with Window Manager(see below). The 2 most popular DE's are KDE and GNOME.
Window Manager - A program that draws Windows to the screen but does not come with any applications or such, typcially bundled in DE's(see above). A popular one is Metacity for GNOME.
X11 - Stands for X Window System. This program provides the foundation for which Desktop Environments are build upon. X11 draws the UI.
XOrg - Xorg is a program that give Linux the ability to have GUI. This is a NOT Desktop Environment or Window Manager! Every program with a GUI requires this to run.
KDE - K Desktop Environment is an environment that tends to feature alot of eye candy and has a more windows feel to it. It uses the QT toolkit. For more information visit http://kde.org.
Gnome - GNU Object Model Environment is environment like KDE that strives for usability. It does not have all the eye candy that KDE has. GNOME uses the GTK toolkit. For more info on Gnome vist http://gnome.org.
XFCE - A Desktop Environment based off of GTK and GNOME, mucher lighter compared to KDE and GNOME, good for older systems. For more information visit http://xfce.org
*box - The *boxes include fluxbox, blackbox, openbox and few others. These are all desktop environments designed to run on minimal resources. You wont get fancy effects like on gnome or kde but on the otherside, the *boxes can run on very low end systems.
Compbiz/Beryl - A Window manager that gives a desktop environment several special effects just as wiggling windows, transparencies, glass windows, and more.
Bootloader Vocabulary
Bootloader - A bootloader is a app that typically resides in your MBR(Master Boot Record). It allows you to select what os to boot on startup.
Master Boot Record - The Master Boot Record or MBR is the 1st few MB on your hard drive. It typically tells what the hard drive should boot aka Linux or Windows. Most times when using Linux a Bootloader resides here.
Grub - GRand Unified Bootloader is a bootloader that allows you to set boot options and additional features at startup. This is the most popular bootloader.
SysLinux - A family of lightweight bootloaders. It's generally used for Live CD's.
Linux Developer Vocabulary
Toolkit - A set of tools usually used to compile programs or make them.
GTK - Gimp Toolkit. A toolkit for X11 for creating GUI's. Used by GNOME, XFCE and many other Desktop Envirments and Apps.
QT Toolkit - A toolkit for X11 for creating GUI's, rivals GTK. Used by KDE and many other DE's + Apps.
File Systems Vocabulary
Swap Space - A partition or file residing on the hard drive varying in space thats used as an extension of memory for the operating system. These are slowly becoming depreciated as computers ship with more and more ram.
ext* - A family of file systems that supports large drives and offers journaling support. Ext4 is the most recent version of this file system. The ext* family is the most used file system in Linux.
XFS - A high performance journaling file system supported by nearly every linux distro.
Paritioning Vocabulary
General note: Linux is not like windows where you generally will have 1 partition for the operating system. A Linux system can have large amounts of partitions. Most common you'll have a /boot, /home and / partition. The advantage of this is you can usually reinstall the operating system without losing your personal data
Extended Partition - A type of partition that can be sub divided into separate logical partitions. Only 1 extended partition can exist on a drive.
Primary Partition - A partition that contains a single file system. Unlike extended partitions you are not limited to just 1 per drive.
I will update this frequently.
EDIT: Seperated LILO and Grub and added Bootloader.
EDIT 6/10: Added MBR, Root and Source.
EDIT: 8/14: More descriptions of package managers, added YaST
EDIT: 6/2: Modifyed some sentences, added Binary, sudo, xorgconfig, xfce, gtk, qt
EDIT: 6/3: Categorized the words, added Pacman, ports, Desktop Envirment, Window Manager
EDIT: 11/7: Added links to KDE and Gnome.
EDIT: 1/23: Seperated Apt-get and apt, added fluxbox, rpm, yum and dpkg-reconfigure xserver-xorg/xfree86, also changed YaST definitions.
EDIT: 4/5: Added Toolkit, Compbiz/Beryl, fixed some spelling errors and reworded some definitions.
EDIT: 2/16/09: Added X11, changed Blackbox to *box to reflect the many DE's based on them.
EDIT: 11/16/10: Reworded some definition, added file systems, partitioning. Removed some obsolete terms.
https://www.neowin.net/forum/topic/325573-faq-linux-vocabulary/
Great work! And here's the obvious nitpicking ;-) :
- Linus Torvalds _started_ the Linux kernel (it was originally called 'Freax', some Usenet admin renamed the folder containing the first release to 'Linux' to honor Linus' work). Many more people work on Linux today, but Linus still is the leader (together with Andrew Morton for Linux 2.6.x)
- It's debatable if Gnome really looks more professional than KDE. I would remove that. They obviously look different, but it's up to the user to decide which one's more professional. Why not provide links to their sites, so that the users decide for themselves?
- The X11 server, based on a common standard by the X Consortium/ The Open Group (X version 11, release 6 right now), has many implementations - next to XFree86 and Xorg, there are, eg, Exceed, Metro X, KDrive, TinyX. It provides a network-transparent, standardized way to draw graphics to the screen, but the only thing about X11 the user usually sees is the black and white pattern when X starts, before the windowmanager is started. The icons and everything get drawn by the desktop environment. BTW, the ugly black and white pattern is there on purpose: A solid color would make it impossible for some monitors to auto-adjust after the resolution changed.
  • 2 weeks later...
  • 11 months later...
  • 1 month later...
Fairly short definitions and in some cases not all that descriptive...
For example, source...source is a human readable language (such as C, Python, Perl, PHP, and Java) that the programmer uses to write the program and it is then compiled or interpreted and then run.
And for KDE, it is a full desktop environment which includes many programs along with the window manager to add usability out of the box.
GNOME goes for a lighter desktop environment and the developers only put what they feel is necessary and go through cleanup cycles every so often to remove what they deem unnecessary. And actually KDE is about to do some cleaning up too (although not as big as GNOME does).
I think some links would help as well.
  • 5 months later...
If you really want to make it accurate take the following into consideration; they're just things that jumped out at me. I don't mean to sound cheeky, just pointing it all out.
It's apt, not apt-get. You also mention YaST as SuSE's package manager, when it uses RPM. YaST, as far as I know is just a front end, much like Syanaptic is for apt, but correct me if I'm wrong.
Where is rpm?
Where is yum?
Where is fluxbox?
It's spelled environment.
Xorgconfig, as I can imagine, is used in more advanced distros, however in Debian and its derivatives dpkg-reconfigure xserver-xorg/xfree86 is used and they're not really programs, but more implementations of the X window system.
Linux, is not the OS. Sure, it's been deemed as it by the media and what not but if you want to get technical GNU is the OS and Linux is the kernel. RMS wrote GNU and needed a kernel. He began development of Hurd and it was a little harder than he thought and couldn't get it to do certain things that he wanted. He came across Linus' kernel and implemented it, however he still to this day is actively working on the Hurd kernel and certain distributions, such as Debian, allow you to use the Hurd kernel over Linus'.
  • 2 months later...
  • 6 months later...
    • I remember when Louis used to just do interesting Mac/iPhone repairs, now he's boring and just launches "crusades" every week
    • A shame it don't allow people to bypass the MS account, I will stick to using Rufus.
    • Microsoft about to radically change how often your Edge browser updates by Paul Hill Microsoft has just announced that starting with Edge 152, it will be moving to a two-week release cycle for faster, smaller updates. This faster release cadence will begin on August 27. This change comes just several months after Microsoft switched Visual Studio Code to weekly updates. The company said that the Extended Stable releases will remain on an eight-week cycle and that no admin changes are needed to experience the faster release cycle on the Stable channel. The new two-week release cycle will enable the faster delivery of security updates and platform improvements, all while reducing the size and complexity of individual updates. Microsoft claims that organizations will benefit from this change as it offers predictable validation cycles. For organizations that prefer a “more deliberate pace”, the Extended Stable channel remains an option. This change will affect Edge Stable releases on Windows, macOS, Linux, and mobile. The Extended Stable channel will continue to be updated every eight weeks, or every fourth Stable release, for example: versions 152, 156, 160, and 164. The Extended Stable could be a good option for organizations that don’t want the latest updates twice a month and don’t want as much hassle constantly updating browsers. In the case of Visual Studio Code, many of the updates being pushed by Microsoft are AI-related. As we all know, Microsoft Edge has a lot of AI features, so we could see Microsoft pushing more AI, thanks to the faster cycles. On the flip side, quicker releases could mean faster security updates, which is beneficial in a world where AI systems are hunting for software exploits. What do you think? Let us know in the comments. For more updates on Edge, be sure to follow Neowin's coverage. In May alone, we reported on Edge offering in-browser pop-ups to assist users with website compatibility issues, that Edge was losing Copilot Mode, and that Microsoft had fixed a plain-text password bug in Edge. Source: Microsoft 365 Admin Center
    • not yet, because at the moment it is not a threat to MS, if and I mean if it did become a threat to MS Office, then it may be a different thing. MS don't like competition
    • Zen Browser 1.21b by Razvan Serea Zen Browser is a privacy-focused, open-source web browser built on Mozilla Firefox, offering users a secure and customizable browsing experience. It emphasizes privacy by blocking trackers, ads, and ensuring your data isn't collected. With Zen Mods, users can enhance their browser experience with various customization options, including features like split views and vertical tabs. The browser is designed for efficiency, providing fast browsing speeds and a lightweight interface. Zen Browser prioritizes user control over the browsing experience, offering a minimal yet powerful alternative to traditional web browsers while keeping your online activity private. Zen Browser’s DRM limitation Zen Browser currently lacks support for DRM-protected content, meaning streaming services like Netflix and HBO Max are inaccessible. This is due to the absence of a Widevine license, which requires significant costs and is financially unfeasible for the developer. Additionally, applying for this license would require Zen to be part of a larger company, similar to Mozilla or Brave. Therefore, DRM-protected media won't be supported in Zen Browser for the foreseeable future. Zen Browser offers features that improve user experience, privacy, and customization: Privacy-Focused: Blocks trackers and minimizes data collection. Automatic Updates: Keeps the browser updated with security patches. Zen Mods: Customizable themes and layouts. Workspaces: Organize tabs into different workspaces. Compact Mode: Maximizes screen space by minimizing UI elements. Zen Glance: Quick website previews. Split Views: View multiple tabs in the same window. Sidebar: Access bookmarks and tools quickly. Vertical Tabs: Manage tabs vertically. Container Tabs: Separate browsing sessions. Fast Profile Switcher: Switch between profiles easily. Tab Folders: Organize tabs into folders. Customizable UI: Personalize browser interface. Security Features: Inherits Firefox’s robust security. Fast Performance: Lightweight and optimized for speed. Zen Mods Customization: Deep customization with mods. Quick Access: Easy access to favorite websites. Open Source: Built on Mozilla Firefox with community collaboration. Community-Driven: Active development and feedback from users. GitHub Repository: Contribute and review the source code. Zen Browser 1.21b changelog: New Features Updated to Firefox 151.0.4 Added 'Space Routing', a new feature that allows you to route links to a specific Space. To get started, click on the three dots in your Space name and click on 'Space Routing Settings'. Fixes Fixed extension-opened tabs not being created with the correct container (#14100) Fixed a bug with the Boosts editor having the wrong theme colors (#14099) Improved overflowing space icons being inaccessible and improved the feeling when hovering over them (#13747) Other minor bug fixes and improvements Download: Zen Browser | 89.8 MB (Open Source) Download: Zen Browser ARM64 | Other Operating Systems View: Zen Browser Home Page | Screenshots 1 | 2 | Reddit Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      davidbazooked earned a badge
      Jamswaz earned a badge
      Marzoid went up a rank
    • Community Regular
      coch went up a rank
      Community Regular
