Nickolius Posted November 1, 2012 Share Posted November 1, 2012 Hello Helper, I have a really hard time to connect to wireless internet. The following information regarding my computer and activity i have done in past. Computer Model: Acer aspire 4520 OS : windows vista 32 bit Network adapter(built in) Atheros This computer was working fine with wireless internet service with my router only. it was not working other router. so i thought let try uninstalled wireless network adapter from hardware. currently, i had install latest driver for this adapter from manufacture site. till now, i can only able to use internet by Ethernet connection. The wireless internet connection does not work at all. This are the symptoms when i try to connect wireless internet. 1)Adapter is working fine in Device manager. 2)Adapter manual switch lite blinking but by pressing on/off it does not do any action to network status. 3) There are no property description and value under adapter property, it just blank. 4)adapter does not list under ipconfig \all command. 5)There are no network listed by clicking connect network into the network and sharing. 6) two results are in diagnose and repair (1) adapter hardware or driver issue. (2) TCP stack binding issue. (3) This adapter does set to correct IP protocol I checked in registry under adapter GUID, looks like all sub keys are not present. I don't have a system restore point before this problem. I tried so many experiment with individual problem but nothing change. I also try connecting with other usb wireless network adapter, did not help same result. So guys please help me out, I don't like to run 25 feet cable in my house. Thank you. Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/ Share on other sites More sharing options...
Detection Posted November 1, 2012 Share Posted November 1, 2012 Change router wireless channel ? Change Encryption type Make sure there is no WPS button on the router you need to press to connect Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595290027 Share on other sites More sharing options...
remixedcat Posted November 1, 2012 Share Posted November 1, 2012 What router do you have?? Also have you tried a USB adapter? Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595290099 Share on other sites More sharing options...
hckngrtfakt Posted November 1, 2012 Share Posted November 1, 2012 Uninstall the device along with the drivers then re-scan for hardware changes (let windows search for new drivers) Finish installation (Restart) Plug your WIRED internet, and do a windows update. check the "optional" updates, as a newer version of the drivers will be there Install, Restart. Done :) Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595290109 Share on other sites More sharing options...
Nickolius Posted November 2, 2012 Author Share Posted November 2, 2012 I am not just trying to connect my router only, but i also looking for a list of other network who broadcast. I used to see almost 5 networks in my list. Now a this days nothing show in network list. by uninstalling driver for this network adapter windows could not find driver itself without online. which i have done both ways and download driver with microsoft update and also adapter manufacture website. I also try attaching a good working usb network adapter in this computer and it does same result. what i have seen in registry after driver software installed is there are not sufficient sub key under network interface, which does not configure network list or ip protocol. I am just guessing. I am not sure but during troubleshooting many time looks like after installing driver software talk to winsock and gether? dll file supply complete information back how to talk this adapter with internet. There are some part missing. it might be some registry corrupted by mistake. Thank you Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595291853 Share on other sites More sharing options...
remixedcat Posted November 2, 2012 Share Posted November 2, 2012 sfc /scannow run that to see if it can fix corruption Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595292301 Share on other sites More sharing options...
Nickolius Posted November 3, 2012 Author Share Posted November 3, 2012 Hello friends, I really appreciate to you for follow-up this problem. "guess what"? finally, my system is up running great. I have done so many troubleshooting point like, update adapter latest driver, check and change setting in service.exe, reset netsh and ipv4, ipv6, and winsock, ipconfig command , disabling firewall(Zone alarm) and lot more play with registry setting. The only way it works for me by uninstalled zone alarm firewall and all components, Then re-installed network adapter driver software for both built-in and usb network adapter working like a charm. It took me almost a week and i almost start to do re-install system but I have a OEM system installed. But anyway, It is a good challenging experience troubleshooting. I really don't know much detail about zone alarm firewall software but somehow there are conflict for old and new hardware or software setting. Thanks again. Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595294285 Share on other sites More sharing options...
remixedcat Posted November 3, 2012 Share Posted November 3, 2012 glad that you got it resolved ;-) Link to comment https://www.neowin.net/forum/topic/1116585-wireless-network-adapter-or-wireless-internet-connection-problem-in-vista/#findComment-595294515 Share on other sites More sharing options...
