- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
HeXetic
I'm looking for some software that will create 2 partitions on a flash drive, Partition Magic doesn't work and neither does Acronis. Free software would be perfect but if not thats still fine.
https://www.neowin.net/forum/topic/474327-help-with-usb-flash-drive-partitioning/Share on other sites
5 answers to this question
