Frustrated users say Google Pixel's latest update does not fix battery drain issue
Image by Steve A Johnson via Pexels
This week, Google announced that it has begun rolling out its May 2026 software update for supported Pixel devices. The update brings a series of bug fixes focused on charging, display stability, camera performance, and UI responsiveness. According to the release notes, the patch addresses a battery-related issue that caused slow wireless charging speeds when battery levels were between 75% and 80% under certain conditions.
However, it does not appear to address the widely discussed idle battery drain problem that is still affecting Pixel users after recent Android updates. These reports from several frustrated users describe excessive battery drain even when phones are not actively in use, with some users claiming devices lose charge unusually fast overnight or while idle. As such the issue status remains open with "no update yet".
On the positive side, the update does include fixes for several usability problems reported by Pixel owners in recent weeks. Google says it resolved a camera bug that could cause the app to freeze while users recorded video and adjusted zoom levels simultaneously. Additional fixes target display-related glitches, including screen flickering, fuzzy visuals, and frozen or noisy lines appearing on some devices. The company also patched issues affecting keyboard and input interface alignment in certain apps.
The full release notes are given below:
Battery & Charging
  • Fix for slow wireless charging speeds when the battery level is between 75% and 80% in certain conditions
Camera
  • Fix for an issue where the camera app could freeze while recording video and adjusting the zoom level
Display & Graphics
  • Fix for an issue that caused a persistent flickering white dot or visual noise to appear at the top of the display in certain conditions
  • Fix for an issue that could intermittently cause the screen to appear fuzzy, frozen, or display noise lines
Framework
  • Fix for an issue where the keyboard or input screen could appear frozen or incorrectly positioned in some apps under certain conditions
The company also shared applicable software update versions for corresponding Pixel models:
Google Pixel model Software Update Version
Pixel 7a CP1A.260505.005
Pixel Tablet CP1A.260505.005
Pixel Fold CP1A.260505.005
Pixel 8 CP1A.260505.005
Pixel 8 Pro CP1A.260505.005
Pixel 8a CP1A.260505.005
Pixel 9 CP1A.260505.005
Pixel 9 Pro CP1A.260505.005
Pixel 9 Pro XL CP1A.260505.005
Pixel 9 Pro Fold CP1A.260505.005
Pixel 9a CP1A.260505.005
Pixel 10 CP1A.260505.005
Pixel 10 Pro CP1A.260505.005
Pixel 10 Pro XL CP1A.260505.005
Pixel 10 Pro Fold CP1A.260505.005
Pixel 10a CP1A.260505.005
You can check out the release notes on Google"s official announcement here. The issue can be found on the issue tracker website here under ID 502262230.
Epic combo deal packs AMD Ryzen 9850X3D, Nvidia RTX 5070, and 850W PSU for under $950
PCIe 8.0 launching in 2028 with a new connector, 8 times faster NVMe SSDs and GPUs
