Specs Appeal: Comparing iPhone 17 Pro with iPhone 16 Pro and iPhone 15 Pro
At the September 9 "Awe Dropping" event, Apple officially announced the iPhone 17 Pro and the iPhone 17 Pro Max smartphones, offering its customers new flagship smartphones with some interesting changes. If you think about upgrading from the previous-gen iPhone Pro or you think about buying one instead of the latest models, here is our spec-by-spec comparison with all the differences between the iPhone 17 Pro/Pro Max, the iPhone 16 Pro/Pro Max, and the iPhone 15 Pro/Pro Max.
Unlike the iPhone 17, which retained the previous design introduced with the iPhone 16, the iPhone 17 Pro/Pro Max has been redesigned. Instead of titanium frames, these phones now use aluminum alloy unibody cases with Ceramic Glass at the front and back. Apple says that the new alloys are lighter and stronger than titanium frames in the iPhone 16 Pro and 15 Pro. The camera module is also new, with the iPhone 17 Pro now featuring a "plateau" with antennas surrounding it.
Displays have not changed much. Sizes and resolutions are the same, except for the peak brightness, which is now at 3,000 nits instead of 2,000 nits (outdoors).
Apple also increased the base storage from 128GB to 256GB, upgraded the processor from the A18 Pro to the A19 Pro with faster CPU and GPU cores, and introduced the new Apple N1 chip for Wi-Fi 7 and Bluetooth 6.
The new camera platform hosts a new array of three 48MP Fusion cameras with up to 8x optical zoom and ProRes video recording with Genlock support. Also, the front-facing camera now has an 18MP square sensor and Center Stage support. This allows you to take portrait or horizontal images while holding your iPhone however you want it. Plus, the smartphone can expand the field of view when it detects another person in the viewfinder. Other new features for the front camera include Dual Capture (record from two cameras at once), Center Stage for video calls and ultra-stabilized video recording.
Finally, Apple equipped its Pro-grade smartphones with larger batteries that promise up to 33 hours of video playback (39 hours in the Pro Max model) and faster charging with a 40W charger (up to 50% in just 20 minutes instead of 30 minutes like before).
Here are the key changes summed up in a list:
  • A brighter display at up to 3,000 nits outdoors
  • Aluminum unibody with Ceramic Glass back instead of titanium frames
  • The new A19 Pro chip with the N1 chip for Wi-Fi 7 and Bluetooth 6, plus the C1X modem with faster performance and better efficiency
  • 256GB base configuration with optional 2TB in the iPhone 17 Pro Max
  • A reworked 48MP Fusion triple-camera setup with Dual Capture, ProRes RAW, Apple Log 2, and Genlock support
  • A new front-facing 18MP camera with a square sensor and Center Stage support
  • Bluetooth 6
  • Bigger batteries with faster charging
  • More expensive: now starting at $1,099 instead of $999
Here is how the iPhone 17 Pro and Pro Max compare to the iPhone 16 Pro and iPhone 15 Pro lineups:
iPhone 17 Pro / Pro Max iPhone 16 Pro / Pro Max iPhone 15 Pro / Pro Max
Display 6.3"
2622x1206
1000/1600/3000 nits brightness
1 nit min brightness
Dynamic Island
Always-on-Display
1-120Hz
6.3"
2622x1206
1000/1600/2000 nits brightness
Dynamic Island
Always-on-Display
1-120Hz
6.1"
2556x1179
Dynamic Island
Always-on-Display
1-120Hz
6.9"
2868x1320
Dynamic Island
Always-on-Display
1-120Hz
6.9"
2868x1320
Dynamic Island
Always-on-Display
1-120Hz
6.7"
2796x1290
Dynamic Island
Always-on-Display
1-120Hz
Case
Aluminum Unibody
206g (7.27oz)
Action Button
Camera Control
Titanium Frame
199g (7.03oz)
Action Button
Camera Control
Titanium Frame
187g (6.6oz)
Action Button
Aluminum Unibody
233g (8.22oz)
Action Button
Camera Control
Titanium Frame
227g (7.99oz)
Action Button
Camera Control
Titanium Frame
221g (7.81oz)
Action Button
CPU 6-core A19 Pro
6-core GPU
16-core Neural Engine
Hardware-accelerated ray tracing
6-core A18 Pro
6-core GPU
6-core A17 Pro Bionic
6-core GPU
RAM 12GB 8GB
Storage
  • 256GB
  • 512GB
  • 1TB
  • 128GB
  • 256GB
  • 512GB
  • 1TB
  • 128GB
  • 256GB
  • 512GB
  • 1TB
  • 256GB
  • 512GB
  • 1TB
  • 2TB
  • 256GB
  • 512GB
  • 1TB
  • 256GB
  • 512GB
  • 1TB
Cameras
48MP Fusion + 48MP Fusion ultra-wide + 48MP Fusion telephoto
0.5x / 1x / 8x optical zoom
Second-gen sensor-shift OIS
Adaptive True Tone Flash
Photonic Engine
Deep Fusion
Smart HDR 5 for photos
Photographic Styles
Macro Photography
ProRAW
48MP Fusion + 48MP ultra-wide + 12MP telephoto
0.5x / 1x / 5x optical zoom
Photonic Engine
Deep Fusion
Photographic Styles
Macro Photography
ProRAW
48MP wide + 12MP ultra-wide + 12MP telephoto
0.5x / 1x / 2x / 5x optical zoom (only in Pro Max)
Photonic Engine
Deep Fusion
Photographic Styles
Macro Photography
ProRAW
Video
4K Dolby Vision video recording up to 120 fps (Fusion Main), up to 60 fps (Fusion Ultra Wide, Fusion Telephoto)
Dual Capture (up to 4K Dolby Vision at 30 fps)
Cinematic mode for videos with shallow depth of field, 4K HDR 30 fps
ProRes RAW
Apple Log 2
Genlock support
ProRes video up to 4K at 120 fps with external recording
Slow-mo video at up to 4K 120 fps
Log video recording
Academy Color Encoding System
Spatial Video recording
4K video at 60 fps
Macro video recording
Action Mode
4K Dolby Vision video recording up to 120 fps (Fusion Main), up to 60 fps (Ultra Wide, Telephoto)
Log video recording
4K video at 60 fps
Action Mode
4K Dolby Vision video recording up to 60 fps
ProRes video up to 4K at 60 fps with external recording
Log video recording
4K video at 60 fps
Action Mode
Front Camera
18MP Center Stage
Center Stage for photos
Dual Capture
Ultra-stabilized video
Photonic Engine
Smart HDR 5
Photographic Styles
Cinematic mode up to 4K HDR 30 fps
HDR video with Dolby Vision 4K 60 fps
12MP
Photonic Engine
Smart HDR 5
Photographic Styles
Data
GSM/EDGE/UMTS/HSPA+
5G (sub-6 GHz and mmWave)
Wi-Fi 7
UWB chip
Bluetooth 6
Emergency SOS via Satellite
Crash Detection
Thread networking technology
GSM/EDGE/UMTS/HSPA+
Wi-Fi 7
UWB chip
Bluetooth 5.3
Crash Detection
GSM/EDGE/UMTS/HSPA+
Wi-Fi 6E
UWB chip
Bluetooth 5.3
Crash Detection
SIM No physical SIM
Dual eSIM support
Battery TBD mAh
33 h video playback
3582 mAh
27 h video playback
3274 mAh
23 h video playback
TBD mAh
39 h video playback
4685 mAh
33 h video playback
4422 mAh
29 h video playback
Ports USB-C (10Gb/s), MagSafe and Qi2
Up to 50% charge in 20 minutes with a 40W adapter
25W wireless charging with a 30W adapter
Up to 50% charge in 30 minutes with a 20W adapter
Colors Cosmic Orange, Deep Blue, Silver Black Titanium, White Titanium, Natural Titanium, Desert Titanium Natural Titanium, Blue Titanium, White Titanium, Black Titanium
Price $1,099+ $999+ $999+
$1,199+ $1199+ $1199+
The iPhone 17 Pro and Pro Max will be available for pre-order on Friday, September 12. Shipments begin on Friday, September 19.
Are you buying one?
Apple announces release date for iOS 26, iPadOS 26, macOS 26, watchOS 26
Apple killed these products after launching iPhone 17 series and Apple Watch Ultra 3
