Discovered amazing battery saving application: Deep Sleep Battery Saver
Google Play download: Free, Pro (trial the pro version untl march 2013 here: http://forum.xda-dev...d.php?t=2030696)
Along with CPU Sleeper (market links: https://play.google....h?q=cpu+sleeper), I almost have no usage with my battery when I turn off the screen. Battery lasted almost two extra days, with my minor usage (only reading e-mails when the auto-sync function gets them, talking on phone about 30-45 minutes in total a day and sending a few sms).
Highly recommending to give this combo (skip the cpu sleeper if you don't have a dual/quad core phone) a try.
edit: Forgot to mention that I also applied the battery saving tweaks from Pimp My Rom, so that might prolong the battery life a bit too.
So, anyone tried it? I wasn't joking about the battery longevity as the result of that combination.
Here's a screenshot of the battery stats, after 24 hours:
Probably could save a bit more power, if I not the battery sucking ingress and world at arms (which for some reason didn't show up in the list).
I've heard a lot of good things about this new app but I'm not too keen on receiving delayed email/whatsapp messages. However I do use the Night mode feature in Battery Widgets Reborn - which puts the device in airplane mode during my sleep hours.
ive tried these programs in the past, and theyve never helped my Rezound. Annoyingly, the previous apps i've tried always disable things i need, like auto-syncing emails. Does this do the same thing? i use my cell phone to get work emails, which i need nearly instantly.
Sorry but that is just plain stupid. What's the point in having a smartphone if you are not going to use it as such? This app turns off your email, Facebook (for those who use it), Twitter, etc and all the services in the background that may or may not be needed (smells like system crash to me).
It basically turns your "smart" phone into a "dumb" phone. I sincerely think that using these apps do more harm than good. Just my point.
I'm pretty sure that as long as your phone lasts you from the morning 'till when you go to bed there is absolutely no need for this battery saving shenanigans. I like having my phone connected all the time, it's what I bought it for.
unfortunately mine doesnt. i'll unplug mine around 7:30am, and im lucky to get home by 5 w/ any charge left. If i DONT use the phone at all, i can make it to about 9pm; however, if im using the phone regularly, it'll be dead w/i 6hrs. Just got a new battery in June, too, btw.
your "smart" phone is still a smart phone when you use it. Depends on your needs.
What phone and Android version are you using? On my GS3 I can easily go longer than a day off a charge, and I use it for all my email, twitter, and some Facebook I will generally pop it on the charger with a good 30-40% left on the battery after 16 hours
It doesn't disable auto-syncing per se. It limits it to the period of your choosing (shortest syncing period the application got is every five minutes) and limits the duration of the auto sync function (15 secs - 5 minute). Which saves the battery by syncing only for specific time and duration and then shuts down until the next syncing.
Here how I got mine set, for my needs: http://i.imgur.com/NtRXe.jpg
You can change it.
You over exaggerating a bit there. You can white list any application from shutting down and even your social networking and email apps aren't constantly syncing to save your battery (check the settings in most of them). So why leave it open, if it's not doing anything but just draining the battery?
if i had a phone together with my usage pattern that would not last a day until i go to bed i would seriously consider to replace it. i tried such apps occassionally but i never found them too useful.
I tried many too. That's the first that actually helped me. After trying the xda pro version for a few days, I forked out and bought it for auto updates.
I admit that I was really interested in trying this when I saw the thread. As I read through the posts and realises that it disables pretty much everything when the display is turned off, I'll give it a miss. My phone can go for the day on a single charge, and I generally plug it in to a power supply whenever possible.
EDIT:
You over exaggerating a bit there. You can white list any application from shutting down...
Ah, so I could whitelist Whatsapp to continue to receive messages the moment that they come in? I guess I would do the same for Skype as well. I'll go and take a look I guess. The worst that can happen is that I end up uninstalling it. Thanks for the tip! (Y)
Same here and I did just that. Brand new phone that was about as dead as a door nail in less than 18 hours. Phone I have now easily last 4 days, with my usage, and NOTHING turned off/tweaked. Not a totally true smart phone, but the one I had that I replaced was, and it sucked all around!!
It's the HTC Rezound running ICS. ive tried all sorts of combinations to save power - limiting syncs, background apps, turning off GPS, wifi, BT. i've tried days w/ 3G only, then days w/ 4G only. doesnt make a difference. i have the brightness turned down to about 30%. you name it, i've tried it. unfortunately, since the rezound has a great screen (still one of the highest ppi), i think it consumes the most power.
Hmm, 5 minutes later and I've uninstalled it. There doesn't seem to be a way to customise the custom profile without paying for the pro version, and I don't want to use a trial version of the pro.
Why not? It's the full pro version (the developer also updates it with every new version) that is valid until March.
Because as it currently stands I haven't provided my bank details to the Play Store, and I don't intend to for the moment. If I haven't added my details by March (which is entirely possible), and if this application does work, I'm going to be disappointed going back to only one day worth of battery life.
As I said before, it's no biggie. I can deal with my battery as it is at the moment.
I am sure you could probably find a download of it bundled with a linux ISO... that just happens to not come with the linux ISO.. even though it should.
I've got the Rezound as well and I can get some great battery life on it. Not sure if you run custom roms, but if you are rooted, one trick you can do is get SetCPU and create a profile to seriously underclock the cpu when the screen is off as you probably don't have much of a need to get things done quickly when the screen is off.
Good one. But no, I'm not going to do that, especially when the app is only 1.95CHF. How low would I have to be to steal 2CHF?
No need for that (for now). Like I mentioned before, the developer actually gives a fully functuioning and updated pro version for free to all to try out... until March.
-edited out-
Not low at all? Jeeze, I steal free stuff :|
    • ImgDrive 2.2.7 by Razvan Serea ImgDrive is a CD/DVD/BD emulator - a tool that allows you to mount optical disc images by simply clicking on them in Windows Explorer. If you have downloaded an ISO image and want to use it without burning it to a blank disc, ImgDrive is the easiest way to do it. ImgDrive features: One-click mounting of iso, cue, nrg, mds/mdf, ccd, isz images Runs on 32-bit and 64-bit Windows versions Mount ape, flac, m4a, wav, wavpack, tta file as AUDIO CD (16-bit/44.1kHz) Mount a folder as DVD/BD Mount images in command line Does not require rebooting after installation Support up to 7 virtual drives at the same time Support multi session disc image (ccd/mds/nrg) A special portable version is available Translated to more than 10 languages Support File Type: .ccd - CloneCD image files .cue - Cue sheets files of ape/flac/m4a/tta/wav/wv/bin .iso - Standard ISO image files .isz - Compressed ISO image files .nrg - Nero image files .mds - Media descriptor image files ImgDrive 2.2.7 changelog: Added command line parameter to set number of drives Added AACS-Auth support for HD DVD Bumped kernel driver version to 2.2.7 Download: ImgDrive 2.2.7 | 692 KB (Freeware, paid upgrade available) Download: ImgDrive Portable 535 KB View: ImgDrive Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • AnyDesk 9.7.7 by Razvan Serea AnyDesk is a fast remote desktop system and enables users to access their data, images, videos and applications from anywhere and at any time, and also to share it with others. AnyDesk is the first remote desktop software that doesn't require you to think about what you can do. CAD, video editing or simply working comfortably with an office suite for hours are just a few examples. AnyDesk is designed for modern multi-core CPUs. Most of AnyDesk's image processing is done con­currently. This way, AnyDesk can utilize up to 90% of modern CPUs. AnyDesk works across multiple platforms and operating systems: Windows, Linux, Free BSD, Mac OS, iOS and Android. Just 7 megabytes - downloaded in a glimpse, sent via email, or fired up from your USB drive, AnyDesk will turn any desktop into your desktop in se­conds. No administrative privileges or installation needed. AnyDesk 9.7.7 fixes: Fixed an issue that prevented users from creating meetings without an active license Download: AnyDesk 9.7.7 | 8.0 MB (Free for private use, paid upgrade available) Links: AnyDesk Home Page | Other platforms | Release History | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • I used a Pixel 10 Pro XL when it first came out for about 8 months. When I first got it, it was using Google assistant and that was fast, when asking it to call somone etc. Then it automatically switched with some update to Gemini. Doing even the simplist of things like asking it to call someone in my contacts was soooooo slow compared to Google assistant. I guess it had to go out to the cloud to do that? Back on iPhone and while Siri is dumb right now, it does do those simple things, like call someone, set a timer, star the stop watch etc, really fast. That an while I like Google Material Design 3 over iOS 26, they Pixel 10 Pro XL was so slow in comparison to the iPhone 17 Pro I am using.
    • I use Gemini in my rotation of AI clients...that work pays for. It is good at most things, better than copilot for imgage searching and making images, worse at writing vs Claude and way worse at hadling technical issues when it comes to Azure stuff. I also use YT premium and maps. Anything else Google is a pass for me. I have now seen multiple people locked out of their Google accounts for reasons that are just very vauge.
    • Microsoft is building an AI datacenter that "uses less water than a fast food restaurant" by Ivan Jenic Image: Microsoft Microsoft has announced plans to build a new datacenter campus in Pecos, Texas, as the company continues to invest billions in AI infrastructure. The new facility, called project Kilby, will reportedly have a capacity of 2 gigawatts and will be one of the largest single capacity additions in the company’s history. To power the campus, Microsoft signed a 20-year deal with Chevron to supply natural gas from the Permian Basin, America's largest oil field. This deal is set to become the largest collaboration to date between a U.S. oil and gas giant and Big Tech. It’s no secret that Big Tech has often been criticized for exploiting natural resources for its AI developments. Microsoft is trying to mitigate some of that negative consensus by promising to build its own power supply for the new datacenter, independent of the public grid. The Pecos datacenter will be powered by a power plant hub, built by Chevron, with up to 2.5 gigawatts of gas-fired capacity, with potential to scale to up to 5 gigawatts. The facility will include at least seven GE Vernova turbines, with first power potentially coming online as early as late 2027 or early 2028. The power plant hub is part of an approximately $7 billion investment by Chevron, making it one of the largest dedicated energy projects tied to a single datacenter campus in the U.S. Microsoft hasn’t publicly disclosed the amount it’s investing in the new datacenter. Microsoft has also committed to implementing a closed-loop cooling system that will only require an initial water charge to operate. The company said that “the total lifecycle water use of this datacenter is only a fraction of that consumed annually by a typical fast-food restaurant.” What the press release doesn’t mention, however, is how much water the natural gas plant itself will consume, or how a 20-year fossil fuel commitment squares with the company's pledge to be carbon negative by 2030. The construction of the new datacenter should provide over 6,000 construction jobs at peak build-out, and create hundreds of operational job roles once the facility is built. Via: Reuters
      tuben earned a badge
      mnsgroup earned a badge
      sumytbe earned a badge
      B4dM1k3 earned a badge
      DarkWun earned a badge
