- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
Andrew T
I have recently purchased NAV 2004 and the first thing I noticed was when an outbound email is sent either from Outlook Express or Outlook ,the progress indicator which should appear in the bottom right hand corner.
What I have noticed,and what is subsequently being reported on a couple of newsgroups,is that the progress indicator displays but behind either of the email clients.
Not a big deal I guess but this never occurred in NAV 2003.It is more annoying than anything else.
Has anyone here on Neowin who uses NAV 2004 noticed this at all? Is this a possible Windows setting or something is not quite right with NAV 2004?
I am running Windows XP Professional.
Edited by Andrew TLink to comment
https://www.neowin.net/forum/topic/100980-nav-2004-problem/Share on other sites
11 answers to this question
