Difference between bootrec and bootsect
Bootsect.exe repairs the boot sector and nothing else. Bootrec.exe can do this too, but it can also repair the MBR and rebuild the boot manager (BCD). So why does bootsect.exe even exist since bootrec.exe can do it's job and more? I don't know. :laugh:
By the way the three command switches you can use are:
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
why do they both exist? Because there are some common features - not everything that bootsect can do can bootrec do, and vise versa.
For example bootrec can not do /nt52 which is for using NTLDR vs BootMGR
  • 1 year later...
  On 11/03/2013 at 01:25, skan said:
Hello
Let's add some more ingredients:
bootsect , bootrec and bcdboot.
Which one is not needed anymore? or Which one can do all?
Which one does the same than EasyBCD?
regards
You need all of them! I use bcdboot more then the others for making bootable images of Windows. Not entirely sure why don't build them into one package but I'm sure MS engineers have some reason albeit because of it just "Always being like that".
