Using MSSoap with VB6 and HTTPS
I am trying to get my VB6 application to interact with a webservice using MSSOAP. My problem occures when i have to change the URL of the webservice to HTTPS. It works fine when i use HTTP but once the application goes to the Production server it will need to be HTTPS. Below is the structure of my code and i notice that the problem occures when i go to pass my parameters to the webservice i get an error, I have also placed the text from the error below my code. Can anyone Help? Thanks.
Dim pstrWebservice As New SoapClient30
Dim pstrResponse As String
Set pstrWebservice = CreateObject("MSSOAP.SoapClient30")
pstrWebservice.MSSoapInit "https://Server-Name/Root-Folder/file.cfc?wsdl"
pstrResponse = (pstrWebservice.webservice(Param1, Param2, Param3, Param4)
[/CODE]
[CODE]
Run-time error '-2147467259(80004005):
Attachment:Maximum retry on the connection exceeded. HRESULT=0x80004005: Unspecified error
-Client:An unanticipated error occured during the processing of this request. HRESULT=0x80004005: Unspecified error
-Client:Sending the Soap message failed or no recognizable response was received HRESULT=0x80004005: Unspecified error
-Client:Unspecified client error. HRESULT=0x80004005: Unspecified
[/CODE]
https://www.neowin.net/forum/topic/1027446-using-mssoap-with-vb6-and-https/
3 answers to this question
  On 22/09/2011 at 15:43, garethevans1986 said:
This may sound daft and doesn't answer your question but why the need to use VB6?
GE
I inheritad the application from another developer, The VB application currently retreives information from an access database, but access database is in the process of being replaced with a coldfusion application and the VB6 application still needs to have connectivity. VB6 is not my first choice for doing this but i don't have any other options untill the VB application is converted to coldfusion.
    • Two ways information like this is passed on. 1. The developers release the "how-to" content and Neowin passes it on. 2. Neowin, or anyone else in the tech community figure out how to do it, Neowin passes it on. Which one are you?
    • On my PC, when using UWP, I have a recurring issue with the scroll bar disappearing after sending a message with a pasted image or text. The only way to fix it was to close and reopen WhatsApp. Now I'll still need this workaround to free up memory in WPA, since that's what I need to do when the WhatsApp tab is consuming 4 GB of RAM after being open for a long time.
    • It’s not just that malware can escape the sandbox but that having Windows Sandbox enabled leaves a vector for malware on the host to hide from AV solutions. The likelihood of this happening must be low but depends on your risk appetite. https://windowsforum.com/threa...x-for-cyber-attacks.356358/
    • https://www.windowsdigitals.com/how-to-remove-items-from-right-click-menu-in-windows-11/
    • Ironically, I do have audio engineering experience, but still find the different flavors of VB-Audio's VoiceMeeter (and more advanced options like Banana and Potato) to be a little unintuitive. Yes, I can figure them out, but despite having a UI that looks like an audio mixer, they don't exactly follow typical audio mixing conventions, so it takes a little time to figure out how the software works. Still, I feel like for what you are asking for, VoiceMeeter is a good solution. If you're interested, I could probably create a quick how-to video.
      Snake Doc went up a rank
      nobody9 earned a badge
      Ricky Chan earned a badge
      leoniDAM earned a badge
      Ian_ earned a badge
      138
      117
