Max Payne 2 Minimum System Requirments
For minimum, these are pretty damn demanding.
From Official Max Payne 2 site:
MINIMUM SYSTEM SPECIFICATIONS
1Ghz PIII/Athlon or 1.2Ghz Celeron/Duron processor
32MB AGP graphics card with hardware transform & lighting support
256MB RAM
1.5 GB hard drive space
Windows 98/ME/2000/XP
DirectX 9.0
Keyboard and mouse
:o
I do have higher then all of that, but thats pretty demanding I think. Anyother games demanding something that high???
Sim City 4 actually requires more than that if your city gets large enough... but that's kind of off topic ;)
I'm not sure there are any games out presently that have minimum sys requirements like that, but I'm more than pretty sure Half-Life 2 and Doom 3 will come close to those, if not go over.
  andRUWeir said:
Doom 3 and Half Life 2 are going to crush those sys requirements, those are only slightly demanding, they're not that bad at all though, my computer will run this, but prob not HL2, don't get so worked up.
You do know right that hl2's gfx engine is scalable with a huge range of hardware, from tnt2 onwards, just that you may not get all the beauties if you don't meet the recommended req's.
My system 'just' meets those requirements :unsure: I hope I can play it, since I'm not sure when I'll get myself a new computer or an upgrade
pathetic requirements. pc hardware is so cheap now you can build a 1.8ghz/512mb/40gb/gf4ti system (including monitor, the works) for under ?500. if your upgrading then its no where near that. i want games wto display min specs to play it at a minimum of 30fps average, not so that it *just* runs. if it said 1.5ghz then i'd be thinking of upgrading (hl2/d3/q4).
  nekrosoft13 said:
i got my new PC Gamer magazine
and they said that the min specs for doom3 are
1ghz p3
geforce 2-up
forgot how much ram
and they said that a "big Hard Drive" will be required
:whistle: i wonder how big
The minimum requirements for Doom 3 are actually,
P3 1 ghz
512 megs ram
Geforce 3 and up
3 GB of hard drive space
Half Life 2's specs are not high since it's very scalable.
P3 500 mhz
DX6 or above compatible video card
256 megs ram
2 gb hard drive
It's recommended is,
P4 2.5 ghz
Radeon 9500 and up
512 megs ram
Max Payne 2's is nothing special. Most games are starting to require a minimum of 1 ghz. And a 32 meg graphics card is low.
