I have an issue where whenever I download, there is a good chance the internet will drop out and I'll have to reset my wireless adapter through the Control Panel to get things running again.
I am not even slightly knowledgable on network related stuff, so instead of going down a potentially long and frustrating route of trying to sort the issue out, I'm wondering if there is a quick way to reset my wireless adapter without having to go through all of the menus and the troubleshooting menus.
This is a bit of a shot in the dark but is there a way to quickly do it? Whenever it happens having I have to wait for the troubleshooting to discover the problem and then fix it, whereas I know that just resetting the wireless adapter straight away would fix it.
  On 02/11/2011 at 17:00, TheReasonIFailed said:
What OS?
This should work on Vista/7.
To disable: netsh interface set interface <interface name> DISABLED
To enable: netsh interface set interface <interface name> ENABLED
I'm on windows 7, where do I type that?
  On 02/11/2011 at 17:03, SHoTTa35 said:
Just resetting the network card brings things back up? Sounds like some offloading going wrong or something. What about upgrading/downgrading drivers?
I think i have the latest drivers but I'll double check.
You'd have to go to the command prompt. Click Start - Type "CMD" - right click and choose admin then type those commands replacing the "<interface name>" with WLAN or whatever the name is.
It's a bit complicated I guess, but you should probably be looking for a real solution instead of bypassing the issue. When you say internet drop out you mean you loose all connectivity or just to the internet. Meaning, can you still ping the router or connect to it or you can't connect to anything?\
Which wireless card is this as well?
Yeah internet dropping or wireless card hanging while downloading should not be happening.. A reset of the wireless card might be a work around but is not the correct path to take.
You need to figure out what is wrong and correct, not some stupid bandaid of resetting the interface.
A quicker way to reset though would be to just disable it and then enable it - this is exactly what that command line is doing, but you can do it in the gui with just click.. Which I believe would be much easier, or you could just create a batch file with the commands and then put a shortcut on your desktop to click.
But again this is not really a solution I would suggest. You really should fix the root of the problem!
it can still recognize and connect to routers, it's just the internet that drops.
it's a tp-link tl-wn851n
Sounds like a simliar problem I had with a laptop, I ended up replacing the wireless card for a new one and everything worked fine after that.
It would randomly drop the wireless when downloading large files/videos/etc after that it would tell you it could see the wireless network it was attached to or that it could see others but it was XP feeding back rubbish information and none of that was actually working as intended.
only fix was to shut down the wireless card (using wifi button or disable/enable in windows) then it would come back to life, drivers etc didn't fix it. New card (as mentioned above) and it all went away :)
Laptop was an old IBM, if that makes a difference
i had the same issues using a belkin wireless dongle on my previous computer. i don't think the issue is the card but how the network is set up maybe. i have no idea where to start :s
"i don't think the issue is the card but how the network is set up maybe."
No highly unlikely -- what could you have setup in the network that would cause the card to reset or hang? Wireless is pretty stupid easy, you setup a WPA psk, or even just OPEN and your done.. There is is nothing to do other than configure the SSID and encryption you want use or not use.
If its crashing, then something wrong with the card/driver or the wireless router. Not any sort of setup in the wireless config that would cause such an issue.
Maybe the card does not like WEP, WPA or WPA2 -- try just open, do you still have the issues? If not then something wrong with there router or card/driver/OS -- if you can connect to the wireless network and it works, then there is not much tweaking or such that could be done that would cause your symptoms.
Other than going open on the encryption -- you could fire up a liveCD and see if you have same issue. if you do not then points to driver/OS issue.
    • They probably mean File Pilot, which this colorful rainbow program can never compete with, because this WinUI crap isn’t made for apps like that. My advice? You should just switch the framework already
    • Scientists uncover bizarre new material that's breaking one of the laws of this Universe by Sayan Sen Image by Ron Lach via Pexels Scientists from the University of Chicago and UC San Diego have discovered a group of materials that behave in surprising ways when put under heat, pressure or electricity. Instead of responding like most materials, these can shrink when heated, expand when compressed, and even bounce back to their original state with the right electric charge. The work focuses on oxygen-redox (OR) materials—types that can help batteries store more energy but typically suffer from stability problems due to structural disorder. In their normal state, the materials follow the usual rules of thermodynamics. But in what's called a “metastable” state, a kind of temporary balance, they behave in reverse. “When heated, the material shrinks instead of expanding,” said Prof. Shirley Meng, senior author of the study published in Nature. This is linked to what’s known as a disorder–order transition inside the material’s structure. The team recorded a negative thermal expansion rate of −14.4(2) × 10⁻⁶ °C⁻¹, which means the material actually contracts when warmed up. This goes against a common theory called the Grüneisen relationship, which usually explains why materials expand with heat. And pressure? Even stranger. When they pushed the material on all sides at levels seen in Earth's tectonic plates, it expanded instead of getting smaller. “Negative compressibility is just like negative thermal expansion,” explained Prof. Minghao Zhang. “If you compress a particle of the material in every direction… it will expand.” They also found that electricity can reset the material’s structure. By tweaking the voltage limits, they recovered almost 100% of the original structure and performance. This has big potential for battery tech, especially electric vehicles (EVs). “When we use the voltage, we drive the material back to its pristine state. We recover the battery,” said Zhang. He added: “You just do this voltage activation… your car will be a new car. Your battery will be a new battery.” The research may lead to materials with zero thermal expansion, helpful in everything from buildings to aircraft. Zhang noted, “Take every single building, for example. You don't want the materials making up different components to change volume that often.” As they move forward, the team wants to understand how redox chemistry can further control these effects and expand practical uses. “One of the goals is bringing these materials from research to industry,” said co-first author Bao Qiu. Their work opens up a new way of thinking about material design, where energy doesn’t just power devices, but reshapes the building blocks themselves. Source: University of Chicago, Nature This article was generated with some help from AI and reviewed by an editor. Under Section 107 of the Copyright Act 1976, this material is used for the purpose of news reporting. Fair use is a use permitted by copyright statute that might otherwise be infringing.
    • "Elon Musk says a kid-friendly 'Baby Grok' is on the way" No kid wants to be a baby anymore. "Kid friendly" I would have named it "Kid Grok"
    • TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 is just $135 by Sayan Sen If you’re juggling gaming consoles, 4K streams and a growing roster of smart devices, the TP-Link Archer GXE75 Tri-Band AXE5400 Wi-Fi 6E Gaming Router is a good option to look at right now, considering the device is currently on sale at just $135 (purchase link under the specs table below). The Archer GXE75 promises up to 5.4 Gbps of throughput across three bands: 574 Mbps on 2.4 GHz, 2402 Mbps on 5 GHz and 2402 Mbps on 6 GHz (HE160 channels enabled). A 2.5 Gbps WAN/LAN port pairs with three 1 Gbps LAN ports and a USB 3.0 port for fast file sharing or printer access (purchase link down below). The quad-core CPU and 512 MB of RAM should help to handle multiple streams without bogging down, while MU-MIMO, OFDMA and 1024-QAM improve efficiency when several devices connect simultaneously. The router’s built-in Game Accelerator engine is said to automatically prioritize gaming packets (both wired and wireless), and TP-Link’s GPN (Gamers Private Network) acceleration can reduce packet loss for supported titles. HomeShield security brings firewall protection, device quarantining and parental controls. The technical specifications of the router are given below: Specification Details Wireless Standards IEEE 802.11ax 6 GHz; IEEE 802.11ax/ac/n/a 5 GHz; IEEE 802.11ax/n/g/b 2.4 GHz Wi-Fi Speeds 6 GHz: 2402 Mbps (802.11ax); 5 GHz: 2402 Mbps (802.11ax); 2.4 GHz: 574 Mbps (802.11ax) Spatial Streams 6 streams (tri-band OFDMA/MU-MIMO) Processor 1.7 GHz 64-bit Quad-Core CPU Memory 512 MB high-speed RAM Ethernet Ports 1× 2.5 Gbps WAN/LAN; 1× 1 Gbps WAN/LAN; 3× 1 Gbps LAN USB 1× USB 3.0 SuperSpeed port (up to 10× faster than USB 2.0) Antennas 4× high-performance external antennas with Beamforming Buttons Power On/Off; Reset; WPS/Wi-Fi; LED On/Off Working Modes Router Mode; Access Point Mode Security WPA, WPA2, WPA3, WPA/WPA2-Enterprise; SPI firewall; Access Control; IP/MAC binding; Application-layer gateway; HomeShield security suite VPN OpenVPN, PPTP, L2TP (server & client); WireGuard (server & client) Software & Services IPv4/IPv6; TP-Link HomeShield; EasyMesh; Parental controls; QoS by device; WAN types (Dynamic IP, Static IP, PPPoE, PPTP, L2TP); DDNS (TP-Link, NO-IP, DynDNS); auto firmware updates Gaming Features Game QoS boost; gaming-port priority; Gamers Private Network acceleration; game-port forwarding; real-time game panel with stats & RGB control Operating Environment 0 °C – 40 °C; 10 %– 90 % non-condensing humidity Get the TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 at the link below: TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 | EasyMesh, HomeShield: $159.99 + $25 off with coupon => $134.99 (Sold and Shipped by Amazon US This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
      Snake Doc went up a rank
      nobody9 earned a badge
      Ricky Chan earned a badge
      leoniDAM earned a badge
      Ian_ earned a badge
      137
      116
