[WPF/C#] element Fade In, Move, Fade Out
Hello gang,
I am playing around with WPF (if you seen the other posts, you know it's having a good time with me)
I need to load an item, in this case it's just an ellipse, have it fade in, move across the screen and then fade out. I am sure I am screwing it up... hence the question. In the example below the Move and Fade Out work, but the fade in does not. If I remark out the Fade out line the fade in works.
myStoryboard.Children.Add(animFadeOut);
[/CODE]
So... what dumb@$$ thing am I doing wrong?
[CODE]
private void button3_Click(object sender, RoutedEventArgs e)
TimeSpan ts = new TimeSpan(0, 0, 0, 12, 500);
StackPanel myStackPanel = new StackPanel();
myStackPanel.Margin = new Thickness(20);
Rectangle myRectangle = new Rectangle();
myRectangle.Name = "MyRectangle";
// Create a name scope for the page.
NameScope.SetNameScope(this, new NameScope());
this.RegisterName(myRectangle.Name, myRectangle);
myRectangle.Width = 100;
myRectangle.Height = 100;
SolidColorBrush mySolidColorBrush = new SolidColorBrush(Colors.Blue);
this.RegisterName("MySolidColorBrush", mySolidColorBrush);
myRectangle.Fill = mySolidColorBrush;
//FADE IN AMIMATION
DoubleAnimation animFadeIn = new DoubleAnimation();
animFadeIn.From = 0.0;
animFadeIn.To = 1.0;
animFadeIn.Duration = new Duration(new TimeSpan(0, 0, 0, 3, 400));
Storyboard.SetTargetName(animFadeIn, myRectangle.Name);
Storyboard.SetTargetProperty(animFadeIn, new PropertyPath(Rectangle.OpacityProperty));
//Y ANIMATION
Int16 iY = 10;
Int16 iX = 500;
TranslateTransform tt = new TranslateTransform(iX, iY);
DoubleAnimation animY = new DoubleAnimation(-(iX + myRectangle.Width), new Duration(ts));
tt.BeginAnimation(TranslateTransform.XProperty, animY);
myRectangle.RenderTransform = tt;
////FADE OUT ANIMATION
DoubleAnimation animFadeOut = new DoubleAnimation();
animFadeOut.From = 1.0;
animFadeOut.To = 0.0;
animFadeOut.Duration = new Duration(new TimeSpan(0, 0, 0, 15, 0));
Storyboard.SetTargetName(animFadeOut, myRectangle.Name);
Storyboard.SetTargetProperty(animFadeOut, new PropertyPath(Rectangle.OpacityProperty));
Storyboard myStoryboard = new Storyboard();
myStoryboard.Children.Add(animFadeIn);
myStackPanel.Children.Add(myRectangle);
this.Content = myStackPanel;
myStoryboard.Begin(this);
[/CODE]
https://www.neowin.net/forum/topic/1054055-wpfc-element-fade-in-move-fade-out/
1 answer to this question
    • thanks for that yeah its real its not fake guys i got it of amazon  how do i fix this please the good thing its not fake
    • Oh Ok thank you,   i'll try to trace which one is the front fans and go from there, i forgot i posted on this issue before oopsy.        But they might already be connected right all i know lol.       I tend to worry way too much i think
    • //merged your topics as they are the same thing. Same answer as well...
    • Facebook's mobile app is finally getting support for passkeys by Usama Jawad Companies and social media platforms are embracing passkeys more readily nowadays. Microsoft made new accounts passwordless by default just last month, Windows 11 has supported passkeys for quite a while, and Google hasn't been left behind either. Interestingly, while passkeys work on WhatsApp too, Facebook hasn't enjoyed the same functionality, even though both apps are owned by the same parent company, Meta. Well, that changes today. Meta has announced support for passkeys in Facebook's mobile app. For those unaware, passkeys are essentially an alternative for passwords, as they allow you to sign in to a service securely using the same means that you use to unlock your device. This includes biometric authentication mechanisms such as facial and fingerprint recognition, as well as PIN. Since you don't need to memorize or externally store a complex password, and the methods highlighted above can't be easily duped, you effectively become more secure when you leverage passkeys. Passkeys were developed by the FIDO Alliance, and Meta is a member of this collective too. Apart from highlighting the benefits of passkeys, such as being pretty much immune to phishing and password spray attacks, Meta has revealed that they are coming to the Facebook mobile app on Android and iOS. They will also be arriving on Messenger in the next few months, and both services will share the same passkey for a more streamlined experience. Meta will also allow customers to utilize this passkey to securely autofill payment information when leveraging Meta Pay. Customers can head over to the Accounts Center in the Settings area to create and manage their passkey, or alternatively, they'll also be prompted to create one when they log in to Facebook next. It is important to note that Meta isn't doing away with passwords on Facebook just yet, as all devices may not be compatible with passkeys.
    • The fact it will show both "real" frames along with generated frames in the bar is amazing. Do we have confirmation if it works across all types - FSR, DLSS, DLSS MFG, XeFG?
      TIGOSS earned a badge
      slackerzz earned a badge
      vivetool earned a badge
      pnajbar earned a badge
      TBithoney earned a badge
      196
