BIOS Settings for CPU Help!
I have just bought a ASRock G41M-VS3 v2.0 and after I updated the BIOS the settings for the CPU speed were lost. As you can see the CPU speed is 1200MHz
So now I have a Intel Dual Core E5700 3.0GHz thats running way too slow and also DDR3 1333 memory thats also running underclocked.
For some resason everything is on Auto including the overclock mode. You would think that it would detect the CPU speed but it doesnt.
So what I am asking is.... what should the settings be for the Ratio CMOS setting and also the CPU and PCIE frequency?
I have tried to adjust them to higher values but I dont understand what they do as to get the correct balance.
Attached is the revelant BIOS screens. I hope someone can help as I am lost when it comes to BIOS settings for memory and CPU etc.
I must say though that this BIOS does allow you to overclock both the memory and CPU. Ive not seen a BIOS that allows this before. Not any I have had anyway.
Thanks for your help!
Matt
post-20157-0-47469400-1330160244_thumb.j
post-20157-0-47246400-1330160254_thumb.j
https://www.neowin.net/forum/topic/1060164-bios-settings-for-cpu-help/
I see that version 1.7 (BIOS Update) modifies the North Bridge default voltage not sure if that is causing the problem! Have you tried to go back to BIOS Version 1.6 and see what that does? What dual core Processor are you using?
  On 25/02/2012 at 11:51, PeterUK said:
Try setting ratio to 15 but its odd that speedstep is disabled....unless you can set ratio to auto to enable it?
This should work^^
Overclock mode to manual
Multiplier @ x15
FSB @ 200
That would give a CPU Speed of 3000MHz
See what your RAM sits at when you set that up.
OK Thanks for that guys. I have set it according to what you posted above and the CPU Speed is now 2990MHz and I have added an additional 4GB stick of DDr3 1333 memory but the memory speed is still at 800.
The speed step is now enabled and on Auto. It enabled after I altered the multiplier. So its sill not quite right. I need to get the memory at 1333.
Your CPU is FS BUS is 800mhz hence the ram will ram at 800 and not 1333mhz... limit to ur CPU/Mobo there http://ark.intel.com...-800-MHz-FSB%29
HOWEVER
mobo states http://www.asrock.co...?model=g41m-vs3
- Supports DDR3 1333(OC)/ - OC meaning OverClock which you will have to Manualy Select and Mobo will never by defauly select this option
in your second picture .. DRAM Fequency where it says Auto ... change that it may have an option to manualy set it to 1333mhz and 1066... if it only shows 800 then ur out of luck for the easy fix ...
READ YOUR MOTHERBOARD MANUAL for the picture says to adjust Jumper Set on the Motherboard before applying 1333mhz to the ram
ftp://174.142.97.10/...al/G41M-VS3.pdf
however reading your manual PAGE 8
4. Please check the table below for the CPU FSB frequency and its
corresponding memory support frequency.
CPU FSB Frequency Memory Support Frequency
1333 DDR3 800, DDR3 1066, DDR3 1333
1066 DDR3 800, DDR3 1066
800 DDR3 800
533 DDR3 800
* DDR3 1333 memory modules will operate in overclocking mode.
* When you use a FSB533-CPU on this motherboard, it will run at
DDR3 533 if you adopt a DDR3 800 memory module.
* If you adopt FSB1333-CPU and DDR3 1333 memory module on this
motherboard, you need to adjust the jumper. Please refer to page 20 for
proper jumper settings.
as your CPU is 800mhz FSB the ram will only ever run at 800MHZ !!!! so thats final end of as PAGE 20 says
FSB1 Jumper
(FSB1, 3-pin jumper, see p.10 No. 26)
If you adopt FSB1333-CPU and DDR3 1333 memory module on this motherboard, you
need to adjust the jumper. Please short pin2, pin3 for FSB1 jumper. Otherwise, the
CPU and memory module may not work properly on this motherboard. Please refer to
below jumper setting.
END RESULT you want your ram to run 1333mhz then buy a new cpu thats 1333mhz FSB!
PS all research done in 5 mins just using google!
