- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
~Matt~
I need to convert a decimal number into a hexadecimal number with "0x" beforehand as the program I am writing needs to be able to create a bitmap image by writing in each hex value. I have written th
My current code is shown below.
However when I want to put my bitCode into an array as follows:
unsigned char drawing[]={bitCode,bitCode,bitCode};
[/CODE]
I get an error that says:[b]incompatible pointer to integer conversion initializing 'unsigned char' with an expression of type char[4][/b]
I think i need to somehow convert it to a string to work. Please tell me what i am doing wrong!
https://www.neowin.net/forum/topic/1068922-c-decimal-to-hexadecimal-conversion-as-string-help/Share on other sites
3 answers to this question
