Technical drawbacks of using a VM ? Are there any ?
Hi all, I have a bunch of Linux Distros Im wanting to test out, and also the CP of Windows 8. I know its not practical to Partition and its Time Costly using Live CDs; so, my question is, if I was to run VBox or VMWare to run the ISOs in, what are the drawbacks of not using "native" hardware ? I understand that there may be speed issues but what other quirks should I know about before I begin ? Also, as I said, Im planning on using VBox and the 30day Trial of VMWare, is there any Distro ( and Win8 ) that will run better in one and not the other ?
Many Thanks in advance for your wise words :)
11 answers to this question
I had no luck running the W8 preview with VirtualBox, although apparently others have had no problems. Anyway, if you'll just be testing operating systems you don't need any VMWare trial, VMWare Player is free and enough for what you need.
Drawbacks? Well, just bear in mind that what the guest OS sees is not the real hardware. After installing the VMWare/VBox guest tools everything should work fine, but you'll likely still find that HW acceleration performance is a bit crappy and sound might not work great.
There aren't any "quirks" in virtualization hence it's widespread use everywhere from data centers to small business. Certainly while demo'ing software, virtualization shines. The only drawbacks you'd encounter are with older processors that don't have the latest virtualization instructions. Also, dedicated graphics support is very limited still in any virtulization software but VMware Workstation is best.
Live CDs are great, but they can be limited still. If you're using a virtual machine, it'd be better to install the actual OS and check for updates. Sounds more like you don't want to reboot and be without Windows/internet while you play around with them rather then needing a VM.
If your CPU supports virtualisation, the guest OS should run at near full speed. What you really need to be aware of is the lack of hardware support from the guest OS. ie Drivers, and that'll be your biggest issue with speed.
VMware is better supported across more Guest OS, however, vbox, if it works for what you want is just as good. I'd try to go with VMWare if you can.. but it really depends what you want to do with them after you've played around with the OSs.
There is no 3d graphics acceleration available as of now in both VMware and virtualbox for Linux distros! So, that's the foremost problem you are going to face if you need to test or run graphic intensive applications!
Other than that, everything should run fine and dandy!
The main drawbacks...That I have seen.
Limitations are based upon the Host OS (speed and number of processors), amount of memory you can spare to the VM.
VM does not have direct access to special features of hardware (such as video cards)- most use a generic video render (some use the S-3 trident) So basically it is software based render which is a bit slower. (but then again it would be just like using an onboard video and only limit is how much memory you can spare from the allotment for the VM to use for video memory.)
Bottom line -- only drawback is if you like a lot of eye-candy and would want to play a game it may have a big drawback. For what they are designed for they work perfectly.
There aren't any disadvantage apart from the performance at least for personal use.
One thing i Have noticed is if you use laptop your battery capacity goes down drastically when using linux(with Ubuntu).
Maybe it was just me but wanted to give a heads up.
    • Display Driver Uninstaller (DDU) 18.1.2.3 by Razvan Serea Display Driver Uninstaller (DDU) is a utility for completely removing AMD/NVIDIA/INTEL graphics drivers and related packages from your system, attempting to eliminate all leftovers (including registry entries, folders and files, driver store). Though AMD/NVIDIA/INTEL drivers can usually be removed via the Windows Control Panel, this uninstaller tool was created for situations where standard uninstall fails, or when you need to fully remove NVIDIA or ATI graphics card drivers. After using this driver cleaner, your system will behave as though it’s the first time you’re installing a new driver—similar to a fresh Windows installation. As with all such tools, we recommend creating a restore point beforehand, allowing you to undo changes if issues arise. If you're having trouble installing an older or newer driver, try it—there are reports that it resolves such problems. Recommended usage: The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best. Make a backup or a system restore (but it should normally be pretty safe). It is best to exclude the DDU folder completely from any security software to avoid issues. You do NOT need to uninstall the driver prior using DDU. Requirements: .NET Framework 4.8 Compatible with Windows 7, 8, 8.1, 10, and 11 (32-bit or 64-bit) Note: Using on Insider Preview builds is at your own risk. Display Driver Uninstaller (DDU) 18.1.2.3 changelog: All GPUs: Fixed hardware rescan issue when cleaning all GPUs without restarting or shutting down UI: Added Guru3D mention in the About section. General: Various fixes and enhancements. Download: Display Driver Uninstaller (DDU) 18.1.2.3 | 1.7 MB (Freeware) Download: DDU Portable | 1.2 MB Links: Display Driver Uninstaller Home Page | Screenshot | Forum Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • That would be nice, if excel could refresh pivot tables without bugs. Frequently you refresh a pivot and all parameters get lost. Now this will happen automatically. Bravo MS!
    • If one could ever put all the crap of the world in one box, that would be Microsoft.
    • The most corrupt and vile CEO any company ever had ! The only company that makes an insane amount of money decade after decade but doesn't deliver on even barely passable quality to customers, screws over partners and treats employees like trash
      Profit earned a badge
      hhgygy earned a badge
      NIKI77 earned a badge
      artistro08 earned a badge
      167
      123
