C# Calculating textbox values?
Hi,
I have an application with 20 textboxes, i need to do the calculations for example ((TextBox12 * TextBox1 * TextBox7) / 2) and display the result on label when clicking a button.
Ive usually done these like this:
private void lBtn_Click(object sender, EventArgs e)
double L, L2;
if (double.TryParse(kTb1.Text, out L) && double.TryParse(kTb2.Text, out L2))
lBl4.Text = String.Format("{0:f1}", (L2 * L));
else
MessageBox.Show("WTF
[/CODE]
I was wondering if there is better way to do this so that I don't have to add all 20 textboxes into this with && double.TryParse?
https://www.neowin.net/forum/topic/1083591-c-calculating-textbox-values/
17 answers to this question
You could add the text boxes into an array, and then iterate over the array...
private void lBtn_Click(object sender, EventArgs e) {
TextBox[] textboxes = {
kTb1,
kTb2,
kTb3,
kTb20
double temp = 0D, total = 0D;
bool isError = false;
foreach (TextBox tb in textboxes)
if (!double.TryParse(tb.Text, out temp))
isError = true;
break;
total *= temp
if (isError)
else
lBl4.Text = String.Format("{0:f1}", total);
[/CODE]
To generate the array, you could create it in the form's constructor (or OnLoad event handler), and store it as a class variable...
[CODE]
TextBox[] m_textboxes;
protected void Form1_Load(Object sender, EventArgs e)
TextBox[] m_textboxes = {
kTb1,
kTb2,
kTb3,
kTb20
[/CODE]
If the only text boxes on the form are the ones you'll be using in the calculation, you could also use the Controls property to get the list of child text boxes :)
  On 12/06/2012 at 12:26, mute~ said:
I'd put the textboxes into a panel, iterate the panels controls where the type is a textbox, load the value into an object then use the object to output your requirements.
Agreed that this is the best way to go.
An application with 20 textboxes sounds like a pain in the ass to begin with. That said, you can at least factor out repetitive code inside methods, for instance you could create an extension method for textboxes to get their value as a double:
public static double getValue(this TextBox txtBox) {
return double.Parse(txtBox.Text;)
[/CODE]
So your code can look like:
[CODE]
try {
lbl4.Text = string.Format("{0:f0}", txt1.getValue() * txt2.getValue() / 3);
catch (Exception) {
[/CODE]
Btw double.Parse with a try-catch (rather than TryParse) is probably the best approach here, it's not like the cost of throwing an exception in this case was of any significance and it leads to cleaner code.
  On 12/06/2012 at 15:47, Dr_Asik said:
An application with 20 textboxes sound like a pain in the ass to begin with. That said, you can at least factor out repetitive code inside methods, for instance you could create an extension method for textboxes to get their value as a double:
<snip>
[/CODE]
How does what you did eliminate repetitive code versus simply using a loop? Using an extension method seems a bit overkill.
Assuming he's doing some operation that involves getting the values of all textboxes indistinctly (like a sum or an average), a loop is the obvious solution, but from his code example I gathered he wants to do operations involving specific textboxes and is wondering how to avoid having to write the double.TryParse boilerplate every time. Maybe I just misinterpreted though, anyway the loop solution was already given by others here.
Actually yeah I see your point now; the first code snippet in the OP seems to suggest arbitrary calculations while the later code snippets suggest otherwise. Interesting.
I wonder if the textboxes are the right way to do this afterall?
This application will have 50 textboxes and user inputs values 1-5. Two buttons, calculate and clear. After the calculations it shows a the results of 8 calculations and also a graph.
I first thought I do it with popup dialog but then decided to use textboxes so that user can check the entered values but it will have alot of textboxes...
Any ideas?
  On 14/06/2012 at 07:31, Joni_78 said:
I wonder if the textboxes are the right way to do this afterall? This application will have 50 textboxes and user inputs values 1-5. Two buttons, calculate and clear. After the calculations it shows a the results of 8 calculations and also a graph. I first thought I do it with popup dialog but then decided to use textboxes so that user can check the entered values but it will have alot of textboxes... Any ideas?
So the user has 5 values to enter and you want to display the result of 8 calculations. Why do you need 50 different fields for that?
I'm not too familiar with Winforms but if you have a lot of data it's usually better to display it with some kind of list control, perhaps DataGrid or ListView.
I meant user needs to enter value 1-5 for every textbox.
Ok so you have 8 different calculations that all require 5 inputs for the user and a field to display the result, if I understand correctly. So you could design a UserControl that has 5 input fields and a result field, and use that 8 times with a different equation passed in as a parameter. The equation could be a five-argument Func where the arguments are the 5 different textbox values. Does that make any sense for you?
  • Like 1
