At what path I must copy the file dbjodbc12.so? What is the correct configuration?
How I can configure the java.library.path under under centos 6 and tomcat 7 in order to fix the problem?
Please help me. If you have any answers please also email me to stavrinc@gmail.com
Thanks in advance
The connection string is as follows:
"jdbc:ianywhere:driver=libdbodbc12.so;ENG=host;DBN=database"
But when running the program, I get the following exception (with the relevant stack trace) -
Exception in thread "main" java.lang.UnsatisfiedLinkError: no dbjodbc12 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1030)
at ianywhere.ml.jdbcodbc.IDriver.try_load(IDriver.java:247)
at ianywhere.ml.jdbcodbc.IDriver.<clinit>(IDriver.java:216
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
1 answer to this question
It should be in java.library.path. You can run this to see what's the actual directory (or directories) for that:
String property = System.getProperty("java.library.path");
StringTokenizer parser = new StringTokenizer(property, ";");
while (parser.hasMoreTokens()) {
System.err.println(parser.nextToken());
[/CODE]
Also you can add the currect location of that library to the java.library.path when launching your app:
[CODE]
java -Djava.library.path=".:/path/to/the/libraryrApp
[/CODE]
