Can not Remote into VMs using machine names
I have created Windows VPN on a Win2k8 server, Outside our local network, i am able to connect to the VPN. Issue i am having is, once i connect to VPN i want to be able to remote into other Virtual Machines on the corp. network using machine names i.e abc:port, it shows an error saying remote desktop connection failed.
I am able to remote into virtual machines using public IP, as well as machine local IP (all virtual machines are configured using static IPs), also i am able to ping all the Virtual machines on the network. So it seems like system is not able to process requests based on machine names. which works fine when accessed locally.
Can anyone tell me what do i need to do regarding this?
Well how are you going to resolve a host name? abc, do you have a wins server? if not then since its not a fqdn (dns like abc.domain.tld) you would have to broadcast for it. You can not broadcast across segments.
So no hostname across a vpn rarely work unless your bridging?
So a few options, use DNS - if your talking w2k8 server - do you have a Domain(AD) then you would have to have DNS - use that to resolve your computers name. If you setup a search suffix for your domain.tld then sure you can use just hostname portion and the dns query will auto add the domain.tld part.
Setup Wins if you want and don't have AD with DNS. Or just setup a host file on your computer that has a listing off all your machines IP and names and then you can use the names to connect like
192.168.1.100 abc
192.168.1.101 dfg
192.168.1.203 xyz
etc.
so for example I run dns on my local network at home, local.lan - and I have my computes in dns - so when I vpn in I hand off this dns
ethernet adapter ovpn:
	   Connection-specific DNS Suffix  . : local.lan
	   Description . . . . . . . . . . . : TAP-Win32 Adapter V9
	   Physical Address. . . . . . . . . : 00-FF-79-1A-85-63
	   Dhcp Enabled. . . . . . . . . . . : Yes
	   Autoconfiguration Enabled . . . . : Yes
	   IP Address. . . . . . . . . . . . : 10.0.200.6
	   Subnet Mask . . . . . . . . . . . : 255.255.255.252
	   Default Gateway . . . . . . . . . :
	   DHCP Server . . . . . . . . . . . : 10.0.200.5
	   DNS Servers . . . . . . . . . . . : 192.168.1.253
	   Lease Obtained. . . . . . . . . . : Tuesday, November 06, 2012 3:11:53 PM
	   Lease Expires . . . . . . . . . . : Wednesday, November 06, 2013 3:11:53 PM
So I can resolve hosts in my network via their fqdn, and my search suffix of local.lan
D:\>ping i5-w7
Pinging i5-w7.local.lan [192.168.1.100] with 32 bytes of data:
Reply from 192.168.1.100: bytes=32 time=121ms TTL=127
Reply from 192.168.1.100: bytes=32 time=131ms TTL=127
Reply from 192.168.1.100: bytes=32 time=119ms TTL=127
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 119ms, Maximum = 131ms, Average = 123ms
The HOSTS file is here: C:\Windows\System32\drivers\etc\HOSTS
The file is a text file, just edit the text file and you should see something like this....
127.0.0.1 localhost
So, just add in the IP address and the name that you want to access it.
If I use localhost in my browser it goes directly to 127.0.0.1, this is how it works.
For example...
127.0.0.1 localhost
192.168.1.100 abcport
I would not suggest you setup AD just so you can use dns - you could always just fire up dns on your w2k8 box you don't have to setup AD for just simple dns.
Easier is just host file - above is the location. You will prob have problem editing it, you need to elevate your text editor to admin to be able to edit the file.
But if you were running AD, more than likely your machines would already be registering themselves in your DNS - so there would be nothing to do but use that dns server and domain suffix in your query from your remote box that vpn'd in.
"Enabling DNS in AD has taken take care of it."
This statement confuses me - you can not have AD without DNS. So there is no enabling it in AD, if you setup AD dns it is part of the setup and would be enabled from the git go.
Do you mean you enabled the DNS role and don't have AD running?
    • Burrrrn. Bought COD WWII last month when it was on sale for PC. Oh well. Excellent game tho, and the PC version plays/looks amazing (and has it's own PC achievements). ...wondering if this is a lesson on waiting on sales. ...also hoping Rise of the Tomb Raider has it's own PC Achievements
    • Google Chrome 137.0.7151.120 (offline installer) by Razvan Serea The web browser is arguably the most important piece of software on your computer. You spend much of your time online inside a browser: when you search, chat, email, shop, bank, read the news, and watch videos online, you often do all this using a browser. Google Chrome is a browser that combines a minimal design with sophisticated technology to make the web faster, safer, and easier. Use one box for everything--type in the address bar and get suggestions for both search and Web pages. Thumbnails of your top sites let you access your favorite pages instantly with lightning speed from any new tab. Desktop shortcuts allow you to launch your favorite Web apps straight from your desktop. Chrome has many useful features built in, including automatic full-page translation and access to thousands of apps, extensions, and themes from the Chrome Web Store. Google Chrome is one of the best solutions for Internet browsing giving you high level of security, speed and great features. Important to know! The offline installer links do not include the automatic update feature. Google Chrome 137.0.7151.120 changelog: [$7000][420697404] High CVE-2025-6191: Integer overflow in V8. Reported by Shaheen Fazim on 2025-05-27 [$4000][421471016] High CVE-2025-6192: Use after free in Profiler. Reported by Chaoyuan Peng (@ret2happy) on 2025-05-31 [425443272] Various fixes from internal audits, fuzzing and other initiatives Download web installer: Google Chrome Web 32-bit | Google Chrome 64-bit | Freeware Download: Google Chrome Offline Installer 64-bit | 128.0 MB Download: Google Chrome Offline Installer 32-bit | 115.0 MB Download page: Google Chrome Portable Download: Google Chrome MSI Installers for Windows (automatic update) View: Chrome Website | Release Notes Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • -Drop the art style, it's cool but doesn't fit the franchise at all. -Make it a gritty single player game, like Halo -Include deathmatch and all that stuff, extraction can be a separate mode If they don't do that, it's dead on arrival IMO.
    • It's a shame because it's one of the best immersive sims ever made, even though it could have used a bit more monster variety IMO.
      Custom Greek Shirts earned a badge
      topantidetectbrowser earned a badge
    • Explorer
      Jdoe25 went up a rank
      Explorer
      190
